imi Posted September 16, 2005 Share Posted September 16, 2005 Hi people. Had a good search around the forum but cant quite find the answer to my problem. - Cars got a FCD, Full-Decat and a Restrictor Ring fitted and a Blitz boost controller + Blitz boost gauge. - Now with the boost controller switched OFF, the boost can read upto 1.7-1.8 bar which is simply crazy..... - Boost controller switched on settings 1 or 2 and its pretty much the same.... Car seems to be pulling strong, however a slight hesitation when the 2nd turbo comes on. Dont like to rag it as really dont want to blow the turbos or the engine... Help appreciated.... Quote Link to comment Share on other sites More sharing options...
Nic Posted September 16, 2005 Share Posted September 16, 2005 So it was running normal boost before? If so it sounds like one of the small hoses has come off or split somewhere. Quote Link to comment Share on other sites More sharing options...
imi Posted September 16, 2005 Author Share Posted September 16, 2005 Yeah, used to run 1.2 bar before....I agree, sounds like somethings split somewhere (too whistly the sound from the turbos spooling).....any pictures of what hoses I am supposed to be checking. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 16, 2005 Share Posted September 16, 2005 No idea which it may be, it'd be my guess that a hose has blown off rather than split though. Have a good look around and see if you can see a hose disconnected. Quote Link to comment Share on other sites More sharing options...
imi Posted September 16, 2005 Author Share Posted September 16, 2005 Thx Nic, will check in the morning... Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 16, 2005 Share Posted September 16, 2005 I'd concentrate around the wastegate area, sounds like you have runaway boost. -Ian Quote Link to comment Share on other sites More sharing options...
