Idle problem.. Driving me crazy
Jam127
Soooo.. Done the swap with my old car (was in an accident :( ), single turbo gte 6speed into an na shell, all went pretty well with not many problems.. Anyhoo im having a bit trouble with steady idle.
When cold it seems to sit where it usually did with an odd blip here and there which i remember it always has. Almost like a small missfire that hasnt caused an issue before
When hot it will sit again normal like it used to with its odd blip
When given throttle it sometimes takes its time to come back down as if the throttle butterfly is sticking - which its not
When driving and i put my foot on the clutch from higher revs it drops and rises from around 600-1100 rpm for around 10-15 seconds then settles again.
One thing i noticed was different on the tt wiring loom and the na loom is there is a plug going to the bottom of the rad that went to some sort of sensor on the tt loom. Now i have read and read about idle problems and people mentioning that the fumes smell rich (which mines does) which is quite alot of the time down to the water temp sensor.. Is this what is at the bottom of the rad on tt's?
I have had the car smoke tested for vac leaks etc and all good.
Also cleaned icv
So this is the only thing i can think of, am i heading in the right direction or miles off? Also how would i go about wiring this part of the tt loom into the na one if need be?
Tried my best to explain :/
Thanks in advance
