cainhead Posted June 24, 2016 Share Posted June 24, 2016 Had a little search on here but couldn't see anything about the expansion tanks on ebay. Has anybody bought one and whats the opinion. http://www.ebay.co.uk/itm/RAW-Aluminum-Radiator-Overflow-Header-Tank-FIT-Supra-Twin-Turbo-2JZ-2JZGTE-/152141669605?hash=item236c59a4e5:g:BgcAAOSwT5tWMs-O CHeers Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 24, 2016 Share Posted June 24, 2016 I'd want to see what type of cap it is and how the coolant returns back to the rad, does the feed pipe go down inside the tank to near the bottom. If it doesn't it wont work and if the cap is pressurised it wont work Quote Link to comment Share on other sites More sharing options...
cainhead Posted June 24, 2016 Author Share Posted June 24, 2016 I'd want to see what type of cap it is and how the coolant returns back to the rad, does the feed pipe go down inside the tank to near the bottom. If it doesn't it wont work and if the cap is pressurised it wont work Will ask the question. If i had a spare OEM rad cap would that solve the issue for the pressure? Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 24, 2016 Share Posted June 24, 2016 It doesn't want to be pressurised, the stock unit just has a press on plastic cap and a breather tube to let air in and out of the tank I've drawn on the how the tube from the cap would look inside the tank Quote Link to comment Share on other sites More sharing options...
cainhead Posted June 24, 2016 Author Share Posted June 24, 2016 It doesn't want to be pressurised, the stock unit just has a press on plastic cap and a breather tube to let air in and out of the tank I've drawn on the how the tube from the cap would look inside the tank Would the standard expansion pipe fit on a normal rad cap fitting? Just a thought if you could use that it would solve the cap and pipe issue. Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 24, 2016 Share Posted June 24, 2016 Would the standard expansion pipe fit on a normal rad cap fitting? Just a thought if you could use that it would solve the cap and pipe issue. I've no idea, but doubt it would be the same size diameter wise Quote Link to comment Share on other sites More sharing options...
cainhead Posted June 24, 2016 Author Share Posted June 24, 2016 I've no idea, but doubt it would be the same size diameter wise Maybe worth a look at the weekend. If there was a good way to adapt it might be worth a try. Quote Link to comment Share on other sites More sharing options...
