dantheman Posted June 21, 2016 Share Posted June 21, 2016 Hi there I currently have a 1994 Na 5 speed manual, I want to single top mount turbo convert it but don't want to buy a pre made kit as I want to learn all about it and how everything works together rather then just bolt it all on and hope for the best aha. So I have a few questions: 1. What's the differences between the Na head and tt head? (Internal parts and port sizes ect) 2. What's the differences between the Na and tt block? (Also internal parts and bore sizes ect) 3. Will the tt rocket covers fit the Na head? (As we all know the look a lot better) 4. What's going to be the best turbo to achieve 800bhp? As this is frazzling my brain [emoji23] Any answers on any of these questions would be a massive help so thanks in advance guys, I'm currently writing a shopping list for all the bits I need and once I've got most of them down I'll be cracking straight on with it. Quote Link to comment Share on other sites More sharing options...
s-u-p-r-a Posted June 21, 2016 Share Posted June 21, 2016 Search button is your friend, lots of handy tips and tt vs na answers, Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted June 21, 2016 Share Posted June 21, 2016 Are you talking 800 RWHP or 800 FWHP? Quote Link to comment Share on other sites More sharing options...
dantheman Posted June 21, 2016 Author Share Posted June 21, 2016 Search button is your friend, lots of handy tips and tt vs na answers, Thanks man I've tried to search a few things but ended up sifting through loads of posts and not really getting to where I wanted [emoji23] new user though so maybe just need to learn my way around more lol Quote Link to comment Share on other sites More sharing options...
dantheman Posted June 21, 2016 Author Share Posted June 21, 2016 Are you talking 800 RWHP or 800 FWHP? Hi bud I'm talking 800 rwhp Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted June 21, 2016 Share Posted June 21, 2016 Hi bud I'm talking 800 rwhp /QUOTE] So your wanting over 900 at the fly? Your 5 speed box isn't going to like that very much! Quote Link to comment Share on other sites More sharing options...
dantheman Posted June 21, 2016 Author Share Posted June 21, 2016 Yer that's the aim and yer I know I'm planning on up grading that to the 6 speed getreg box [emoji1] Quote Link to comment Share on other sites More sharing options...
Parm_93 Posted June 22, 2016 Share Posted June 22, 2016 What are you planning to do with the block? Cylinder head? What internals are you going to use and how much are you willing to spend? 800WHP does not come cheap, and if you have limited knowledge, I wouldn't even attempt doing it myself.. Quote Link to comment Share on other sites More sharing options...
Style Posted June 22, 2016 Share Posted June 22, 2016 1. Manifold patterns are different. Pistons and headgasket size are also different to give a higher compression ratio. You'll need to change those for your power goals. NA runs a distributor so you'd best change that to coil packs so you can run TT cams etc. 2. NA doesn't have oil squirters, probably wise to install them for 800rwhp 3. Yes 4. Precision, Borg Warner etc. there's quite a few choices. A lot to consider and carry out. If you're new to this I'd suggest a lot of research and careful planning as this isn't an easy project in one jump. I'd probably get an NA-T conversion done on a stock engine, distributor and just a set of injectors. Once you're confident that's running fine, build engine, ramp up the boost a bit to 500-600hp and get that running. Then make the last jump if you want to Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 22, 2016 Share Posted June 22, 2016 Can I ask why your aiming for 800 whp ? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted June 22, 2016 Share Posted June 22, 2016 For that sort of power level, you will need to build the head and bottom end. I don't know of any GE engines running on stock internals at 900 fwhp Quote Link to comment Share on other sites More sharing options...
