Help with dead Motorbike - immobilised?
carl0s
My friend has bought an ex-stolen-recovered Honda CBR600F bike, and it doesn't work.
There is no ignition barrel, (four cut wires instead), and it has no spark or ignition. He is pretty good with mechanical stuff and thinks there's a problem with the ECU (pictured). I suspect it has an in-built immobiliser or something. He has found out that he can get a replacement ECU for £450 from Honda.
Does anybody know anything about these bikes, or can anybody suggest a good forum to discuss further?
Can the ECU's be recoded or anything? Does the ignition barrel do something a bit more tricky than simply act as a switch?
Please excuse the shite pictures. Camera phones really are useless.
This is what I understand to be the ECU.
http://www2.css-networks.com/bike/1.jpg
The four cut-wires from where the ignition barrel would be.
http://www2.css-networks.com/bike/2.jpg
VIN plate. Does this say anything useful?
http://www2.css-networks.com/bike/3.jpg
http://www2.css-networks.com/bike/4.jpg
This is the alarm that was on it. I presume it just detects motion/tilt, and activates the horn & lights. Doesn't look like a problem.
http://www2.css-networks.com/bike/5.jpg
Here it is in all it's glory, minus fairing..
http://www2.css-networks.com/bike/6.jpg
http://www2.css-networks.com/bike/7.jpg
Can anybody help?
I presume the bike thief got it going ok by hotwiring after cutting the ignition switch, right? That would mean it's not immobilised, wouldn't it? AFAIK Honda don't have an on-ECU immob system.
I would start by replacing the broken Ign switch. That's the most likely problem. I can't see it being an ECU issue. It's going to need another switch anyway
You might get more help over at u.k.rec.motorcycles
What year is it?
Mine is 1999 (1100 model though) and from then onwards they've had immobiliser in the ignition key.
In the key? :D
I didn't know Honda did their own integrated immobilisers though. My '98 CBR900RRW doesn't have one. Maybe it's only on the luxobarge Blackbird models :p
Do you know where the immobiliser brain is located? It might help Carl find his one.
In the key? :D
yep
Thatcham Cat 2 I think it is.
Keys and ECU are a (pricey) set
200cc less, maybe thieves wouldn't be interested :stickpoke
We don't want to start another UK vs JSpec saga now do we? :ecstatic:
OK, you started it...
OK, it is a bit lardy (make that a LOT)
The turning circle is not far off the supra's (I'm not kidding!)
Manouevering the thing at parking speeds is tiring and clumsy (it's loooong and heavy)
But once speeds are over 100 it's very stable.
Nothing ever goes wrong either (unlike the Bayahusa which I didn't go for)
[/hijack] :D
thanks guys! After coming over here, he went and spoke to a chap round the corner from his house, who said basically the same - ignition barrel and ECU need to both be replaced as a matched pair.
Time to start searching breakers.. Are there bike-specific breakers or just any-old breaker?
I'll head over to uk.rec.motorcycles next, cheers.
