Cam Cover removal 1993 N/A
tintinmt
I think if you follow the part of the loom that goes down to the bottom left of the picture it is sort of clipped to a metal bracket, releasing it from this gives you a bit more play to get it out the way, up and forward as already suggested.
As Scooter says, just work your way around to the bolts. Tip though - cover the open area as all sorts of bits of the old wrapping tape will break off, they'll be very brittle. Also don't be surprised if the odd crack develops in the hard plastic. This happened to me despite being very careful.
Also (as some miss this) make sure you have the correct packing sealant for the corners around the front end of the cam cover, it's essential and will leak very soon if you don't use it.
I didn't know this. Timely advice as I'll be replacing my cam cover rubber gasket soon. I've already got the gasket, but didn't know I need sealant as well. I presume any automotive gasket sealant will be OK?
The torque is quite low so I think you need to be careful you don't over do it. Also once mine were loose a week or so later and needed nipping down (perhaps the seal compressed a bit or I was to careful torqueing them up as I don't have a low range wrench so am guessing!?)
I think a general sealant will do, main thing I'd say is use a good degreaser/brake cleaner on a cloth to prep the surface then just use a small blob (look at the size of squeezed out bit before removal)
