Parm_93 Posted June 13, 2016 Share Posted June 13, 2016 AFR and Boost gauge in one. Comes with all pipework, cables and wideband sensor. It does fit into the stock clock location nicely too . Not just your standard gauge, full spec of what it can do can be found here: http://www.aemelectronics.com/?q=products/gauges/failsafe-gauges/wideband-failsafe-gauge SOLD Parm. Link to comment Share on other sites More sharing options...
Slam Posted June 13, 2016 Share Posted June 13, 2016 Just what I need. But can't afford it. Dam. Link to comment Share on other sites More sharing options...
supra_ufo Posted June 13, 2016 Share Posted June 13, 2016 can you swap between the boost and afr? and in the same position slam LOL Link to comment Share on other sites More sharing options...
Parm_93 Posted June 13, 2016 Author Share Posted June 13, 2016 can you swap between the boost and afr? and in the same position slam LOL Yeah you can do it on the configuration software, so you can have the centre digital bit reading boost pressure, and the outer ring reading the AFR or vice versa. I had them as both AFR though as I had a separate boost gauge . Link to comment Share on other sites More sharing options...
supra_ufo Posted June 13, 2016 Share Posted June 13, 2016 Yeah you can do it on the configuration software, so you can have the centre digital bit reading boost pressure, and the outer ring reading the AFR or vice versa. I had them as both AFR though as I had a separate boost gauge . ah cool, I have defi boost gauge and a boost controller. If its around at the end of the month I might buy it Link to comment Share on other sites More sharing options...
Parm_93 Posted June 13, 2016 Author Share Posted June 13, 2016 ah cool, I have defi boost gauge and a boost controller. If its around at the end of the month I might buy it Cool man let me know Link to comment Share on other sites More sharing options...
Parm_93 Posted June 15, 2016 Author Share Posted June 15, 2016 .. Link to comment Share on other sites More sharing options...
Parm_93 Posted June 18, 2016 Author Share Posted June 18, 2016 Up Link to comment Share on other sites More sharing options...
Parm_93 Posted June 20, 2016 Author Share Posted June 20, 2016 Up Link to comment Share on other sites More sharing options...
Parm_93 Posted June 22, 2016 Author Share Posted June 22, 2016 Now £200 posted Link to comment Share on other sites More sharing options...
Parm_93 Posted June 25, 2016 Author Share Posted June 25, 2016 . Link to comment Share on other sites More sharing options...
