ABS ECU -- Tap into for Motec Traction Control
Jellybean
Hi
Car: 2JZGTE Non-VVTI MM6 JPEC
I want to tap into the ABS ECU (Speed Sensors) , the ECU is behind the radio , from looking online ,Looks like there might be an option to splice into the white footwell connector. Looking at the RTLC for VVTI , we seem to have a mix of pins , some non-vvti are the same as VVTI etc
Question
  1. Anybody know the correct pin outs for my car ?
  2. Do i need to remove the dash panel to splice into the speed sensors or is there a white plug in the footwell?
  3. I think we only have two ABS systems as outlined below? If so I will just use a volt meter and see what setup is in my car
For Reference
RTLC for VVTI
http://www.mkivsupra.net/vbb/showthread.php?70518-VVTi-Jap-Spec-RLTC-fitting
FR+ A21-3 (red)
FL+ A21-8 (white)
RR+ A20-10 (blue)
RL+ A20-22 (purple)
Small Plug
Pin 3 Red wire .......Front Right Wheel
Pin 8 White wire......Front Left Wheel
Large Plug
Pin 10 Blue Wire......Rear Right Wheel
Pin 22 Purple Wire....Rear Left Wheel
Just looking at post 6 in this thread there is a white footwell connector.
http://www.mkivsupra.net/vbb/showthread.php?232824-J-Spec-Engine-Harness-Connector-Details&p=2956347&viewfull=1#post2956347
Pin Wire Colour Function Destination(s)
1 N/A No Connection N/A
2 N/A No Connection N/A
3 N/A No Connection N/A
4 Yellow-Blue Unknown Traction ECU pin 15
5 Green-Red Rear Right Wheel Speed Traction ECU pin 12
6 Purple-Red Front Right Wheel Speed Traction ECU pin 14
7 N/A No Connection N/A
8 N/A No Connection N/A
9 N/A No Connection N/A
10 N/A No Connection N/A
11 N/A No Connection N/A
12 N/A No Connection N/A
13 Brown-White Handbrake switch Traction ECU pin 16
14 N/A No Connection N/A
15 Purple-White Rear Left Wheel Speed Traction ECU pin 11
16 Blue-Orange Front Left Wheel Speed Traction ECU pin 13
Edited by Jellybean (see edit history)
