Dim Sum Posted June 11, 2016 Share Posted June 11, 2016 I am planning to buy a set of Volks TE37 SL. I was wondering if anyone could tell me the wheel fitment needed for the Supra. I am planning to run 18" with these wheels. Quote Link to comment Share on other sites More sharing options...
Scooter Posted June 11, 2016 Share Posted June 11, 2016 You going new ie can order what you like or are you considering a use set? Stock 17's are 8" front 9.5" rear. Generally widths wise people go for between that and 9" front 10" rear. People don't tend to stick to the stock widths or offset because they often want wider rubber but also want to 'fill the arches' as the stock wheels sit in the arch which is out of fashion/looks pants to some. So with filling the arches in mind, once people decide on the widths they then need to decide on offsets, stock are 50, as you come down in offset so the wheel sticks out further from the hub and so fills the arch 'better'. A 10" rear wheel will already stick out a quarter of an inch more than a stock 17" wheel, I think sensible non wheel arch rolling offsets are in the 40's as you go into the 30's you are moving into arch work territory. Personally if I wanted to go wider than stock rubber I'd be looking at 8.5" and 10" with 42-45mm offset but that's being unconcern re the look, others I'm sure can advise on that if you want that too. Nice choice of light wheels by the way! Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted June 11, 2016 Author Share Posted June 11, 2016 Thanks. Taking me ages to decide on the wheels. I dont fancy rolling any arch's, what you said 8.5r front and 10r rears what about 40mm offset? Maybe it will hit the arch? Have anyone fitted these wheels? Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted June 11, 2016 Author Share Posted June 11, 2016 What about 18" X 9.5 +45 fronts and 10.5 +45 rear? Quote Link to comment Share on other sites More sharing options...
