Sound problem on pc
Dnk
My mothers pc is quite old and is Windows XP
If I play a CD in it its fine and not bad sound quality, it has new Creative speakers.
If I play a youtube video the sounds very bad almost like the pc can't do both things at the same time.
Any suggestions to help fix this problem, without buying a new pc :)
Thanks
Thanks
Make sure the pc is using the correct sound device in sound properties.Or look at these.
Buy a 16 bit or 32 bit soundcard, PCI not PCie that should take over some of the CPU based sound stress. Could try re-installing direct X and switching hardware acceleration off or on.
http://smallbusiness.chron.com/turn-off-hardware-acceleration-sound-card-68509.html
http://www.ebay.co.uk/itm/Creative-Sound-Blaster-Audigy-SE-7-1-PCI-Sound-card-/122011001697?hash=item1c686c2361:g:RmIAAOSwnNBXWbvL
May help.
We had it apart and fitted a new sound card and graffix card, did some major cleaning up defragmenting etc as it was getting
painfully slow to operate, its now way quicker but has this sound issue
I'll have check what sound card was fitted
XP isn't supported anymore. As time goes on, developers no longer care if features work on the OS anymore so you're going to start running into problems more regularly. You also won't get security patches, although that doesn't mean there aren't security problems still being found. If it's running XP, the hardware is likely to be about 10 years old, so it will be very slow by modern standards. Software tends to bloat up to run acceptably on kit built within the last 3-5 years.
Not the answer you want, but you really should be looking to replace it.
Failing that you could try a clean rebuild from a genuine windows XP CD and just put the drivers you need on, not the manufacturer bundled crapware. That'll get the best possible performance from the box, it may still have sound problems though. You will need to backup any data before trying this though.
  • 4 months later...
From these pro innovation solutions on fleabay, I buy a lot of second hand stuff from here, stick an SSD in and they'll fly, just buy at the right time, I usually end up getting something for £30-40, then a new ssd for £40 and jobs a good un. If you struggle let, me know.
http://www.ebay.co.uk/itm/HP-Pro-3135-3305-MT-PC-AMD-Athlon-II-X2-3GHz-3-2GHZ-2-0GB-DDR3-FREE-P-P-/272433065129?hash=item3f6e46aca9:g:3FUAAOSw44BYF1uL
http://www.ebay.co.uk/itm/Dell-Optiplex-790-Desktop-PC-Intel-Core-i3-2120-Dual-Core-3-30GHz-2-0GB-DDR3-DP-/291930099386?hash=item43f863ceba:g:fwgAAOSwHMJYGLMl
Video is also jerky, a pal says its a buffering issue
A buffering issue sounds like bollocks, all that means is that it can't load the next frame of video before it's played the current one. Buffering problems will either be your network speed, or a software issue (driver or codec). It is incredibly rare that buffering problems are caused by hardware.
Afraid i'm only a beginner at this so can only go on what i get told, the network speed is good, i think that was nearly 50 mbps
  • 2 weeks later...
