supra_24 Posted June 7, 2016 Share Posted June 7, 2016 Hey guys, Went to a local MOT workshop this morning to get the Supra's MOT done and it failed on the first emissions test. They checked the exhaust pipe with a probe and failed it due to a 1% difference. Also they were not happy with it being decatted. I found this very strange as the car has passed all its previous MOTS with it being decatted and emissions etc. I was under the impression that due to it being an import and 1993, that it wouldnt go by the same regulations for emissions as newer cars etc? My V5C even states its a 1993 import and has no emissions listed to go by. They stated I needed a CAT fitted, but to be honest, their is nowhere to fit one on a single turbo setup. So I am a bit lost on where to go from here? Supra Specs is as follows: 1993 2JZ engine single turbo conversion Whifbitz 264 Cams Syvecs ecu 800cc injectors Remapped via Litchfields and Whifbitz Borg Warner 6262 single turbo twin scroll. Screamer pipes and twin wastegates. Aftermarket BOV. Single turbo exhaust downpipe. HKS silent high power exhaust decat. Whifbitz exhaust manifold. Can anyone please advise on the above? That would be most appreciated. Thank you. Kind Regards. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted June 7, 2016 Share Posted June 7, 2016 Its cars 1991 or older that emissions don't matter. Do you have a lean mode for MOT purposes on a Syvecs calibration? I thought we all know people that can magically turn our cars into a KIA C'EED or something similar for 10 mins during an emissions test Quote Link to comment Share on other sites More sharing options...
supra_24 Posted June 7, 2016 Author Share Posted June 7, 2016 It was set to low boost during the intial test. Thats one of the lowest maps I have. Also reading on here. It should have had a pre 95 import non-cat test. On the flow charts it states that if no data on the system is found regarding emissions it goes via a non-cat test. They put mine through a CAT test. But no details regarding my car and emissions would be on the system due to it being an import. This is where I am confused. Any further advice on this matter? Quote Link to comment Share on other sites More sharing options...
Scooter Posted June 7, 2016 Share Posted June 7, 2016 not sure if this link is up to date but there will be a similar flow chart. I think you want them to go down the non cat test route, claiming you can't find the specific car in the database, ie they' should use the UK spec supra limits (might be hard to argue against depending how picky they are. https://www.google.co.uk/search?q=non+cat+test+chart&biw=1600&bih=861&source=lnms&tbm=isch&sa=X&ved=0ahUKEwitp9WrmZbNAhUQOsAKHX--AegQ_AUIBigB#tbm=isch&q=non+cat+emissions+test+chart&imgrc=uHgiecn5bC4-1M%3A There has to be something that could be stuffed down the exhaust round the corner from the test station eat would absorb hydrocarbons and CO to get round this.....any chemists on here! Quote Link to comment Share on other sites More sharing options...
supra_24 Posted June 7, 2016 Author Share Posted June 7, 2016 not sure if this link is up to date but there will be a similar flow chart. I think you want them to go down the non cat test route, claiming you can't find the specific car in the database, ie they' should use the UK spec supra limits (might be hard to argue against depending how picky they are. https://www.google.co.uk/search?q=non+cat+test+chart&biw=1600&bih=861&source=lnms&tbm=isch&sa=X&ved=0ahUKEwitp9WrmZbNAhUQOsAKHX--AegQ_AUIBigB#tbm=isch&q=non+cat+emissions+test+chart&imgrc=uHgiecn5bC4-1M%3A There has to be something that could be stuffed down the exhaust round the corner from the test station eat would absorb hydrocarbons and CO to get round this.....any chemists on here! Yeah i did see that chart. The thing is it should be a non-cat test surely as only the UK Spec would be listed on their system and mine is clearly an import from Japan (Jspec) Dont see how else a single turbo Supra is gonna pass an MOT otherwise? You cant even buy a CAT for this setup, so that is out the window. ANyone have a single turbo setup that can advise? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted June 7, 2016 Share Posted June 7, 2016 Just take it to a friendly garage instead of messing around with cats... Quote Link to comment Share on other sites More sharing options...
supra_24 Posted June 7, 2016 Author Share Posted June 7, 2016 Just take it to a friendly garage instead of messing around with cats... Does anyone on here know of a friendly garage based in Berkshire then? Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted June 7, 2016 Share Posted June 7, 2016 It was set to low boost during the intial test. Thats one of the lowest maps I have. Also reading on here. It should have had a pre 95 import non-cat test. On the flow charts it states that if no data on the system is found regarding emissions it goes via a non-cat test. They put mine through a CAT test. But no details regarding my car and emissions would be on the system due to it being an import. This is where I am confused. Any further advice on this matter? Low boost maps wont be lean maps.. Might be worth contacting your mapper, but sounds like it maybe worth going down the route of a different test station, might be worth just visiting else where and saying that there's no cat and if they can help Quote Link to comment Share on other sites More sharing options...
secondjump Posted June 7, 2016 Share Posted June 7, 2016 My local are stringent with the MOT test. When I had a single turbo on a 93 rz I just swapped out the mid pipe for the second cat and changed it back afterwards. Any reason why you can't do the same? Quote Link to comment Share on other sites More sharing options...
herbiemercman Posted June 8, 2016 Share Posted June 8, 2016 Hi Supra24, Hope this link helps. Herbie. http://www.mkivsupra.net/vbb/showthread.php?333765-Total-decat-mot-test-!-!-! Quote Link to comment Share on other sites More sharing options...
Homer Posted June 8, 2016 Share Posted June 8, 2016 Does anyone on here know of a friendly garage based in Berkshire then? PM on it's way to you. Provided the car passes all other MOT tests it'll get put through in a legitimate way and thus bypassing the cat check. It's entirely legal. Quote Link to comment Share on other sites More sharing options...
supra_24 Posted June 8, 2016 Author Share Posted June 8, 2016 Hi Supra24, Hope this link helps. Herbie. http://www.mkivsupra.net/vbb/showthread.php?333765-Total-decat-mot-test-!-!-! Thanks for all your help guys. I should hopefully now be able to get something sorted out with my Supra. I will update you once I get it all sorted. Probably wont be able to do so until end of June now, so will let your know nearer to that time Quote Link to comment Share on other sites More sharing options...
