Mk4Gaz Posted June 5, 2016 Share Posted June 5, 2016 Hi all, hoping someone can help Just recently my overdrive button has stopped working, so I cannot turn it off. I'm going for mapping soon, so need to get this fixed...... I modded the auto lever a while back, and made a mental note of what way the two wires from the button, went into the blue 4 pin plug. After removing the shifter trim, I realised that both wires have come out (I wish I'd soldered/crimped them now), but I'm not sure where they're supposed to go. Could anyone with an auto take a picture of how theirs is - making a note of what pins the wires should line up with please? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 7, 2016 Share Posted June 7, 2016 It's only a switch so which way around the wires go does not matter Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted June 7, 2016 Author Share Posted June 7, 2016 Thanks Chris, but, the two wires from the overdrive button, go to a 4 pin plug. It's what pins I need to connect to that I'm not sure of Quote Link to comment Share on other sites More sharing options...
clay Posted June 7, 2016 Share Posted June 7, 2016 IF you dont have any luck mate. you can look at mine if you wont. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 7, 2016 Share Posted June 7, 2016 I can get a photo but probably nut until tomorrow, when I am fitting a speedometer converter and will have the panels out of a TT auto. Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted June 7, 2016 Author Share Posted June 7, 2016 IF you dont have any luck mate. you can look at mine if you wont. Cheers buddy, hopefully Chris won't mind taking a picture, and that will be enough. But, if I get really stuck, I'll let you know Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted June 7, 2016 Author Share Posted June 7, 2016 I can get a photo but probably nut until tomorrow, when I am fitting a speedometer converter and will have the panels out of a TT auto. Thanks Chris, would be very much appreciated Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 8, 2016 Share Posted June 8, 2016 Lousy photo, sorry, but does this help at all? Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted June 8, 2016 Author Share Posted June 8, 2016 Thanks Chris, but unfortunately it doesn't! I've had another look, and the wires in the 4 pin plug are: White/green trace White/black trace Green/orange trace Purple/green trace. Basically, I just need to know what two of those pins, the overdrive button should connect to Quote Link to comment Share on other sites More sharing options...
kayjay0_7 Posted June 8, 2016 Share Posted June 8, 2016 Think the colours you need are White/black and violet/green Quote Link to comment Share on other sites More sharing options...
kayjay0_7 Posted June 8, 2016 Share Posted June 8, 2016 Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted June 8, 2016 Author Share Posted June 8, 2016 Legend, thanks kel, hopefully that's right Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted June 8, 2016 Author Share Posted June 8, 2016 Just in case anyone is as daft as me in the future, I can confirm that kelvin was correct. One side of the switch goes to the violet/green trace, and the other side goes to the white/black trace Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 8, 2016 Share Posted June 8, 2016 Glad you are sorted for whatever reason the camera would not do a close focus today. Quote Link to comment Share on other sites More sharing options...
