Big Mark Posted June 3, 2016 Share Posted June 3, 2016 I need to get made a simple bracket out of some 3mm (ish) thick aluminium sheet. Bracket is only small so (smaller than a postcard) but a bit too fiddly to cut by hand neatly. Any one on here got or know someone that has a water jet of laser cutter? Quote Link to comment Share on other sites More sharing options...
Digsy Posted June 3, 2016 Share Posted June 3, 2016 Companies with laser cutters should be easy to find, they are more common than you might think. I have one locally who I have used a few times - they usually charge a few quid for one-offs if I can supply them with a DXF file for programming the machine and a simple drawing. Quote Link to comment Share on other sites More sharing options...
Big Mark Posted June 4, 2016 Author Share Posted June 4, 2016 Thanks. I'll search locally then. Quote Link to comment Share on other sites More sharing options...
