Understanding wheel fitments
Dim Sum
I have never really looked into the the wheel fitments as I always brought wheels in description says its for a Toyota Supra mk4.
what are the biggest fitments I can have without rolling the arches?
Will these fit?
Width : 8J (Front) & 9J (Rear)
Diameter : 18 Inch
Offset : ET42 (Front) & ET35 (Rear)
Width : 8.5J (Front) & 9.5J (Rear)
Diameter : 19 Inch
Offset : ET35 (Front) & ET35 (Rear)
Edited by Dim Sum (see edit history)
So I should in theory be able to fit this fitment in:
Diameter : 18 Inch
Are you running these sizes on stock arches ?
If so could you tell me your front size too :D
I might just copy it, I know I should run wider tyres but I am hoping to get the R888 summer tyres and that should handle the power. I don't drive the Supra in the wet
My current wheels at the rear are 19" 9.5J et35 tyres 275/30 (or 35 not sure) stock not rolled arches, all ok.
Decision, decision, decision.
So based on your set up I should be able to run these 19" then. Since they are the same offset and width.
Diameter : 19 Inch
you should be fine, my wheels are exactly: fronts 19" 8.5J et30 ( they are et35 but with 5mm spacers to clear UK brakes it is et30 ) tyres 235/35. rears 19" 9.5J et35 tyres 275/30. I will say that's the max for standard car. Maybe with different et you can go wider. Ah my car have standard suspension (reas) and it is not lowered.
I have done about 7k miles on them, that included 4k eurotrip (UK - France - Italy - Croatia - Slovenia - Austria - Poland - Germany - UK) many different roads (motorways, local roads, bumpy roads, lovely german autobahns) and all was ok.
