jot_ie Posted May 29, 2016 Share Posted May 29, 2016 Well, I bought the Halfords 3/4" breaker bar, and a 3/4" impact socket. Removed undertray and braced the bar off the ground. Turned the ignition ....... nothing. The front just rises about an inch, damn bolt will not budge. Where to now?? Quote Link to comment Share on other sites More sharing options...
MattP Posted May 29, 2016 Share Posted May 29, 2016 Toyota locking tool+ breaker bar+Scaffold pole+ heavy set strong assistant= success Quote Link to comment Share on other sites More sharing options...
jot_ie Posted May 29, 2016 Author Share Posted May 29, 2016 Toyota locking tool+ breaker bar+Scaffold pole+ heavy set strong assistant= success Have all of the above except for locking tool :-( Quote Link to comment Share on other sites More sharing options...
Scooter Posted May 29, 2016 Share Posted May 29, 2016 You are manual so you can put it in gear and handbrake firmly on and try the bar plus extension plus brute force. Not easy to torque it up accurately this way but you should get the nut loose. Quote Link to comment Share on other sites More sharing options...
Scooter Posted May 29, 2016 Share Posted May 29, 2016 Also I've never done the starter method, but doesn't it involve having a gap between the bar and ground to give an initial movement and therefore a bigger shock type impact/torque on trying the starter? Quote Link to comment Share on other sites More sharing options...
MattP Posted May 29, 2016 Share Posted May 29, 2016 Just done mine a few month ago on an Auto the crank bolt was new last year when I did the timing belt oil pump/etc and it wouldn't budge this time with the "starter motor trick" I torqued the bolt up to exact spec last year aswell so no overtightening to blame. The locking tool really is magic these self made ones I keep seeing are trash in comparison. Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted May 29, 2016 Share Posted May 29, 2016 +1 for locking tool. Had a few times where starter trick worked and others where locking was required Quote Link to comment Share on other sites More sharing options...
ronttuk Posted May 29, 2016 Share Posted May 29, 2016 anyone got a photo of the locking tool? Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted May 29, 2016 Share Posted May 29, 2016 anyone got a photo of the locking tool? http://www.garagewhifbitz.co.uk/toyota-2jz-1jz-crank-pulley-lockup-tool.html Quote Link to comment Share on other sites More sharing options...
MattP Posted May 29, 2016 Share Posted May 29, 2016 ^ that's where I got it in the end aswell Toyota wanted £300 for it I shit you not... The one I made just bent the m8 bolts as there is no support for them into the crank pulley face where as the Toyota tool has support for the two bolts. Quote Link to comment Share on other sites More sharing options...
jot_ie Posted May 30, 2016 Author Share Posted May 30, 2016 You are manual so you can put it in gear and handbrake firmly on and try the bar plus extension plus brute force. Not easy to torque it up accurately this way but you should get the nut loose. Been trying this, swinging out of it like a chimp. No go. Theres no danger I will do damage if I really force it is there? Also I've never done the starter method, but doesn't it involve having a gap between the bar and ground to give an initial movement and therefore a bigger shock type impact/torque on trying the starter? Tried that too, leaving a bit of slack to get that jolt, no joy. At the moment I can't justify the cost of the locking tool, just for one use. Quote Link to comment Share on other sites More sharing options...
MattP Posted May 30, 2016 Share Posted May 30, 2016 Been trying this, swinging out of it like a chimp. No go. Theres no danger I will do damage if I really force it is there? Tried that too, leaving a bit of slack to get that jolt, no joy. At the moment I can't justify the cost of the locking tool, just for one use. That was my problem I was buying for most likely one use however all other attempts had failed and I put on a wanted ad to borrow one but apparently nobody on the forum has one. They are heavy aswell so by the time you pay postage or travel costs+ a tip for said person who borrows you the tool your pretty much half way there to buying your own. I spent hours trying to make my own tool to no avail as it just bent the bolts. Just bite the bullet and buy one you can always sell it after and take a small hit which you could consider rental. Quote Link to comment Share on other sites More sharing options...
jot_ie Posted May 30, 2016 Author Share Posted May 30, 2016 It is very much looking like I will have to. I will try borrowing one from the local garage, if they hav on, other than that I feel a purchase is necessary. Quote Link to comment Share on other sites More sharing options...
MattP Posted May 30, 2016 Share Posted May 30, 2016 Tried that aswell even the 3 closest Toyota dealers didn't have one they lease the tools apparently and if they don't get used they go back. And small garages just insisted my air gun will take it off (it didn't) Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 30, 2016 Share Posted May 30, 2016 Get the garage to do the job Quote Link to comment Share on other sites More sharing options...
jot_ie Posted May 30, 2016 Author Share Posted May 30, 2016 Get the garage to do the job I have gotten stubborn now :-) Unfortunately I cant move the car, Calipers are off for a refurb, no radiator, cam covers, fan belt or battery Quote Link to comment Share on other sites More sharing options...
Scooter Posted May 30, 2016 Share Posted May 30, 2016 Been trying this, swinging out of it like a chimp. No go. Theres no danger I will do damage if I really force it is there e. I don't think so. I have the bar coming up the passenger side by the battery tray (I'd remove that too so you start with it against the inner wing/chassis bar) and then push it in toward the engine (rather than pull from the other side) as high up the bar as you can, mine is so long it can hit the bonnet so be careful if yours is the same. It will go/crack with an almost scary bang/jolt, but it will go. Quote Link to comment Share on other sites More sharing options...
JordanC Posted May 30, 2016 Share Posted May 30, 2016 I ended up buying the SST for the job, starter method was just shattering breaker bar heads for me! Quote Link to comment Share on other sites More sharing options...
jot_ie Posted May 30, 2016 Author Share Posted May 30, 2016 I don't think so. I have the bar coming up the passenger side by the battery tray (I'd remove that too so you start with it against the inner wing/chassis bar) and then push it in toward the engine (rather than pull from the other side) as high up the bar as you can, mine is so long it can hit the bonnet so be careful if yours is the same. It will go/crack with an almost scary bang/jolt, but it will go. That's exactly what I ended up doing. Put it in 6th gear, handbrake on, bar positioned as you have described, and after much pushing and pulling nothing happened. After various contortions and swinging about like a chimp, I ended up standing on the engine and pulling it towards me with a 6 foot steel pipe extension. It was too long to stand on the ground and push it, couldn't reach the end to get all the leverage It did go though, success finally :-). Some crack out of it. Quote Link to comment Share on other sites More sharing options...
Annabella Posted May 30, 2016 Share Posted May 30, 2016 Yay! You'll be like Tarzan now Quote Link to comment Share on other sites More sharing options...
jot_ie Posted May 30, 2016 Author Share Posted May 30, 2016 Yay! You'll be like Tarzan now Haha, Cheetah more like, any zoo would be proud to have me :-) Quote Link to comment Share on other sites More sharing options...
bebby Posted May 31, 2016 Share Posted May 31, 2016 Make sure you get an oem pulley as I bought an eBay special, bang on 2 years later and 30000 miles I needed a new one so learnt from my mistake and got genuine Quote Link to comment Share on other sites More sharing options...
jot_ie Posted May 31, 2016 Author Share Posted May 31, 2016 Make sure you get an oem pulley as I bought an eBay special, bang on 2 years later and 30000 miles I needed a new one so learnt from my mistake and got genuine Yes indeed, most definitely, Going to be changing the timing belt and tensioners, crank pulley and bolt, water pump and gaskets, thermostat, fan belt, rad hoses and clips all new parts from Toyota. Basically a front end refresh . Quote Link to comment Share on other sites More sharing options...
bebby Posted May 31, 2016 Share Posted May 31, 2016 Yes indeed, most definitely, Going to be changing the timing belt and tensioners, crank pulley and bolt, water pump and gaskets, thermostat, fan belt, rad hoses and clips all new parts from Toyota. Basically a front end refresh . Pretty much exactly what I did 2 years ago when my tensioner fell apart, hence trying to save money on the crank pulley, learnt from that mistake Quote Link to comment Share on other sites More sharing options...
jot_ie Posted May 31, 2016 Author Share Posted May 31, 2016 Pretty much exactly what I did 2 years ago when my tensioner fell apart, hence trying to save money on the crank pulley, learnt from that mistake I can fully understand saving the money, I have spent a small fortune on mine over the last 2 years. It was stolen and damaged, so quite a bit of rebuilding. Not quite back on the road yet, but getting there . I have read some horror stories because of using spurious parts. Much better to wait and do it right, there are just some mission critical parts that should not be messed with. Quote Link to comment Share on other sites More sharing options...
