Coombesy Posted May 29, 2016 Share Posted May 29, 2016 so driving the other day and my speedo just stopped working, all the other dials still work fine. I was a couple of hours away from home, which was ball ache but got home using the the sat nav for speed! Then when I go to get in it to take it too the garage I get warning lights and when idling it would either idle high or really low and cut out. At the garage they took the speed m8 converter out to see if it was that causing the speedo problem, which it didn't. Just wondered if anyone had any idea what could be causing these issues? Link to comment Share on other sites More sharing options...
martincoupe Posted May 29, 2016 Share Posted May 29, 2016 which box are you runnig ? and is the car import ? could gbe speedo sensor or speedo converter beghind dash or simply a loose wire Link to comment Share on other sites More sharing options...
supra_ufo Posted May 30, 2016 Share Posted May 30, 2016 when mine went on my auto box it was the actual wheel cog that sits on the speed sensor (it was warn), you can buy them new from Toyota for less than £20 Link to comment Share on other sites More sharing options...
Coombesy Posted May 30, 2016 Author Share Posted May 30, 2016 It's an import 6 speed manual thanks for the info. Hopefully won't be too much of a pain Link to comment Share on other sites More sharing options...
