berg Posted May 29, 2016 Share Posted May 29, 2016 Anyone know of, or recommend a good aftermarket replacement manifold gasket and manifold studs and nuts that are of decent quality for the GTE? Been quoted £70 for the gasket (2pcs) and then another £70 for a set of 12 studs and nuts, genuine Toyota which in my opinion is ridiculous I don't want to use one of those cheap cardboard silver gaskets with the dots on as ive heard they are crap Ive found a seller who has a stud and nut kit for £30 but unsure of quality Any ideas? Link to comment Share on other sites More sharing options...
np89 Posted May 29, 2016 Share Posted May 29, 2016 Have you tried tcb parts? Link to comment Share on other sites More sharing options...
berg Posted May 29, 2016 Author Share Posted May 29, 2016 Yer they sell the gaskets at around £50 with the vat which is the best ive found so far and they have no studs or nuts Cant believe its so much money for a bloody gasket lol Link to comment Share on other sites More sharing options...
ripped_fear Posted May 29, 2016 Share Posted May 29, 2016 As above tcb stock the studs. Great company to deal with can't recommend them high enough Link to comment Share on other sites More sharing options...
JackyBoi Posted May 29, 2016 Share Posted May 29, 2016 Why not use Toyota MLS? I got mine for £60 from Toyota. Can't help with the nuts and studs though Link to comment Share on other sites More sharing options...
np89 Posted May 29, 2016 Share Posted May 29, 2016 If the studs arent done I wouldnt bother. If it aint broke dont fix it. Nuts are a good call though. Shouldnt be much from toyota themselves if you do it via part number Link to comment Share on other sites More sharing options...
David P Posted May 29, 2016 Share Posted May 29, 2016 I used stainless steel bolts and cut the heads off to convert them to studs, this allows the stud to use the 10mm? of unused threads in the holes. They need installing with 2 nipped nuts and with more stud into the aluminium threads they are stronger than stock and never rust. Cheap as chips too. Link to comment Share on other sites More sharing options...
berg Posted May 29, 2016 Author Share Posted May 29, 2016 Studs i was only buying as a "just in case", so if any broke i had some to hand ready, which is why i didnt want to spend £70 on parts i may not use Can get the nuts at just under £2 each so around £20 for the 12 which i will be replacing regardless Guess ill just have to fork out for the gasket as much as i dont want to lol Link to comment Share on other sites More sharing options...
berg Posted May 29, 2016 Author Share Posted May 29, 2016 (edited) I used stainless steel bolts and cut the heads off to convert them to studs, this allows the stud to use the 10mm? of unused threads in the holes. They need installing with 2 nipped nuts and with more stud into the aluminium threads they are stronger than stock and never rust. Cheap as chips too. Interesting method, thats what puts me off using the cheap ebay stud kit, ive seen how they rust on other cars and snap when removing a short time later Do you know the thread spec? EDIT: M10 x 1.25mm looks to be the correct pitch Edited May 29, 2016 by berg (see edit history) Link to comment Share on other sites More sharing options...
David P Posted May 29, 2016 Share Posted May 29, 2016 Interesting method, thats what puts me off using the cheap ebay stud kit, ive seen how they rust on other cars and snap when removing a short time later Do you know the thread spec? It's been a long time since I rocked that roll and can't remember those details. M8 or M10 1.5 or 1.25? The weakest point is the aluminium threads in the head and with more steel further into them can only make them stronger. Link to comment Share on other sites More sharing options...
Guest Budz86 Posted May 29, 2016 Share Posted May 29, 2016 Side note, probably worth running a tap down the thread just to clean it up if you're going to fit the studs deeper Link to comment Share on other sites More sharing options...
Dim Sum Posted May 30, 2016 Share Posted May 30, 2016 The stock thread size is what David P said, its a M10 with 1.25 pitch. You can go on ebay and buy that size nuts and can get them in slim size's, that's what i used for my greddy tubular manifold Link to comment Share on other sites More sharing options...
trebor69 Posted May 30, 2016 Share Posted May 30, 2016 Fensport do studs, not saying they're cheap but this is where I buy my repair studs from 01354 696968. Link to comment Share on other sites More sharing options...
cainhead Posted May 30, 2016 Share Posted May 30, 2016 Studs i was only buying as a "just in case", so if any broke i had some to hand ready, which is why i didnt want to spend £70 on parts i may not use Can get the nuts at just under £2 each so around £20 for the 12 which i will be replacing regardless Guess ill just have to fork out for the gasket as much as i dont want to lol Sorry to high jack this a little but do you have the part number for the nuts. I'm just installing new studs myself on the turbo side as installing a single setup. Had a couple which were sized to the nut but whole thing came out all okay. I just ordered 4 x studs to replace the seized ones from whifbitz as they had them in single quantities. Think they were around £5 each if you are only needing a few just in case. Link to comment Share on other sites More sharing options...
berg Posted May 30, 2016 Author Share Posted May 30, 2016 Have no idea on the part numbers myself I just ordered it all through driftmotion in the states in the end as i was ordering some other bits from them Worked out around £70 for the gasket studs and nuts together genuine toyota which is alot cheaper than here Link to comment Share on other sites More sharing options...
cainhead Posted May 30, 2016 Share Posted May 30, 2016 Will check that out need the gaskets myself Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 31, 2016 Share Posted May 31, 2016 I think I still have OE TT turbo manifold to head gaskets available. If you need extra nut clearance on tubular manifolds I can supply the wonderful Aerospace K nuts in the correct thread. Link to comment Share on other sites More sharing options...
cainhead Posted June 1, 2016 Share Posted June 1, 2016 Thanks Chris, have sent you an email for the price. Link to comment Share on other sites More sharing options...
