David P Posted May 26, 2016 Share Posted May 26, 2016 I have stumbled across an aluminium Supra radiator with a built in ATF cooler same as stock rad. http://www.ebay.co.uk/itm/Radiator-For-TOYOTA-SUPRA-A80-Automatic-Transmission-Cars-Replacement-Brand-New-/162082441465? Link to comment Share on other sites More sharing options...
Rajinder Posted May 27, 2016 Share Posted May 27, 2016 Interesting. I have never seen one for auto before. Need some feedback or spec how thick the core is etc. Link to comment Share on other sites More sharing options...
Burna Posted May 27, 2016 Share Posted May 27, 2016 Wile found and fitted a rad with an auto cooler built in ages ago, but not sure what make or where from. Link to comment Share on other sites More sharing options...
evinX Posted May 27, 2016 Share Posted May 27, 2016 Looks nice, replaced mine recently and a chrome one would have looked the nuts in my bay Link to comment Share on other sites More sharing options...
jackso11 Posted March 22, 2017 Share Posted March 22, 2017 http://www.ebay.co.uk/itm/ALUMINUM-RADIATOR-FOR-TOYOTA-SUPRA-JZA80-2JZ-GTE-TURBO-1993-1998-AUTO-MANUAL-/162436999861?hash=item25d1ffeab5:g:zfwAAOSwr~lYs751 There are a few of them about Link to comment Share on other sites More sharing options...
Mk4Gaz Posted March 22, 2017 Share Posted March 22, 2017 I've had one fitted to mine for a couple of years Link to comment Share on other sites More sharing options...
jackso11 Posted May 10, 2017 Share Posted May 10, 2017 I went for the ASI full ally one and tried to fit it today.....the locating lugs on the bottom are about 1cm to far apart for a good fit so I had to kind of stretch the rubber mounts. The I noticed the near side top of the radiator is hard against the front slam panel of the car and to top it off the bonnet doesn't close. Either they have sent me the wrong one or they are just cheap crap. Link to comment Share on other sites More sharing options...
Frank Bullitt Posted May 10, 2017 Share Posted May 10, 2017 I went for the ASI full ally one and tried to fit it today.....the locating lugs on the bottom are about 1cm to far apart for a good fit so I had to kind of stretch the rubber mounts. The I noticed the near side top of the radiator is hard against the front slam panel of the car and to top it off the bonnet doesn't close. Either they have sent me the wrong one or they are just cheap crap. That is the reason I recommended you buy one from Chris Wilson in your best replacement radiator thread. Chris supplied mine and you couldn't tell it apart from the OEM one that was shot, fitment was spot on. Link to comment Share on other sites More sharing options...
jackso11 Posted May 10, 2017 Share Posted May 10, 2017 That is the reason I recommended you buy one from Chris Wilson in your best replacement radiator thread. Chris supplied mine and you couldn't tell it apart from the OEM one that was shot, fitment was spot on. Think I will be giving him a ring tomorrow. I went for this ASI one after seeing a few posts on here saying they had them fitted and are perfect. The one they sent me is far from it, £120 down the drain as I am 2 days over the garanteed return window on ebay and I bet the seller doesn't answer my messages. Link to comment Share on other sites More sharing options...
Annabella Posted May 10, 2017 Share Posted May 10, 2017 Think I will be giving him a ring tomorrow. I went for this ASI one after seeing a few posts on here saying they had them fitted and are perfect. The one they sent me is far from it, £120 down the drain as I am 2 days over the garanteed return window on ebay and I bet the seller doesn't answer my messages. Doesn't matter, if something isn't as described, then they'll take it back. Link to comment Share on other sites More sharing options...
jackso11 Posted May 10, 2017 Share Posted May 10, 2017 I hope so. Link to comment Share on other sites More sharing options...
jackso11 Posted May 11, 2017 Share Posted May 11, 2017 They have come back to me and agreed to refund so that is good. Link to comment Share on other sites More sharing options...
Delboy52 Posted May 11, 2017 Share Posted May 11, 2017 (edited) Good that you noticed in time Adam. I bought one ages ago and stored it until the fitting time came around so no refunds. The locating pins are too far back so the front face is banging on the chassis and still not located in place on the rubber mounts. Same story with the upper mount points, the OE restraint brackets don't reach. It's like the ports were all added to the wrong side as everything is offset. Myself and David have persevered with it so hopefully on the next fitment attempt it'll sit properly but it has needed the locating pins cutting off and re-welding into a new position. The bonnet clears mine but the lower edge touches the under tray mount points so that will need a tweak. Would use a proven brand or OE if buying again. Edited May 11, 2017 by Delboy52 (see edit history) Link to comment Share on other sites More sharing options...
