S.P.R. Posted May 25, 2016 Share Posted May 25, 2016 Could this be the tail light relay? As soon as I turn the ignition on, the tail lights are on, even with the sidelights/dipped beam switch off. When I turn this on it blows the panel illumination fuse... Brake lights and front headlights all work fine. The retro fit rear fog in to the brake lights does not work but part of the switch takes power form the illumination wire from the dash dimmer. It's a J spec NA, can anyone help? Quote Link to comment Share on other sites More sharing options...
