dude Posted April 10, 2003 Share Posted April 10, 2003 can anyone explain the correct way to connect the vacum pipe to the solenoid on the sbc-id , do both actuators need to be connected and if so best way to do it or just the big one between the manifold and inner wing , help . John:flame Dev Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted April 10, 2003 Share Posted April 10, 2003 John, follow this install guide. http://www.mkiv.com/techarticles/blitz_dsbc/index.html It is exactly the same for the SBC version. I didn't see it in that article but the top of the actuator needs to be plugged, i.e. a bolt clamped inside the old hose. Quote Link to comment Share on other sites More sharing options...
Alex Posted April 10, 2003 Share Posted April 10, 2003 The vac hose is t'd off of my boost gauge and runs into the cabin from there into the control box. "T" it of any manifold pressure hose of a big enough diameter. Quote Link to comment Share on other sites More sharing options...
dude Posted April 10, 2003 Author Share Posted April 10, 2003 Thanks Martin what i dont understand is that in the instructions it gives a diagram for seq.twin turbos that shows using BOTH actuators not just one , there is an actuator for each turbo ??? so why not plumb in both . John:flame Dev Quote Link to comment Share on other sites More sharing options...
dude Posted April 10, 2003 Author Share Posted April 10, 2003 Alex its the solenoid im not sure of . john:flame Dev Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted April 10, 2003 Share Posted April 10, 2003 Ahhh i understand the confusion now. Only follow the instructions as shown on MKIV.com. The actuator for the first turbo works as an exhaust gas bypass allowing No2 to spool up as well. (think that's right, but it's getting late and i'm tired.) In summary you don't need to worry about the first turbo, just connect to the forward most wastegate and that will be fine. That is how most of us have ours connected. Quote Link to comment Share on other sites More sharing options...
