Help with Thresholds for Measurements
Jellybean
Hi
Setting up Thresholds for Alarms , I want to measure the below
  1. Engine Temp (Celsius)
  2. Oil Temp (Celsius)
  3. Fuel Pressure (PSI)
  4. Oil Pressure (PSI)
Engine/Oil Temp --
  • Cold under X Degree Celsius
  • Just about up to temp
  • At Temp threshold (Between X temp and Temp)
  • Getting hot (Between X Temp and X temp)
  • In the Red
Fuel Pressure -- at what pressure and above is WOT
Oil Pressure -- Good, Bad , and the Ugly
thanks
Oil temps id say cold until 80 degrees, getting warm until 105, all good until 120, up to 130 is the limit, alarm after that.
Oil pressure varies with rpm so anywhere up to 8.5bar is what I see. cant remember the low pressure trip for the life of me. But moving on clutch with no throttle will be where it's at its lowest.
