mrboomberang Posted May 22, 2016 Share Posted May 22, 2016 After putting on oem exhaust system today i have the warning light on the dashboard ? Link to comment Share on other sites More sharing options...
Scooter Posted May 22, 2016 Share Posted May 22, 2016 What warning light? When you say stock exhaust just cat back? Nothing should have happened to be honest on an exhaust swap. Link to comment Share on other sites More sharing options...
mrboomberang Posted May 23, 2016 Author Share Posted May 23, 2016 The one on the Rev content red with black triangle Link to comment Share on other sites More sharing options...
mrboomberang Posted May 23, 2016 Author Share Posted May 23, 2016 Not just cat back full system back on Link to comment Share on other sites More sharing options...
mrboomberang Posted May 23, 2016 Author Share Posted May 23, 2016 Link to comment Share on other sites More sharing options...
Scooter Posted May 23, 2016 Share Posted May 23, 2016 hand brake obviously off yes? Link to comment Share on other sites More sharing options...
JasonR24 Posted May 23, 2016 Share Posted May 23, 2016 Did you put the sensor back in? Link to comment Share on other sites More sharing options...
mrboomberang Posted May 23, 2016 Author Share Posted May 23, 2016 What sensor. ? Link to comment Share on other sites More sharing options...
JasonR24 Posted May 23, 2016 Share Posted May 23, 2016 O2 sensor Link to comment Share on other sites More sharing options...
mrboomberang Posted May 23, 2016 Author Share Posted May 23, 2016 O2 sensor is before the cat never to he'd that Link to comment Share on other sites More sharing options...
mrboomberang Posted May 23, 2016 Author Share Posted May 23, 2016 Never touched that Link to comment Share on other sites More sharing options...
Jellybean Posted May 23, 2016 Share Posted May 23, 2016 If it is a TT Jspec , it is a Cat Temp Sensor on 1st cat; normally when you decat you just tie it up out of the way Link to comment Share on other sites More sharing options...
mrboomberang Posted May 23, 2016 Author Share Posted May 23, 2016 If it is a TT Jspec , it is a Cat Temp Sensor on 1st cat; normally when you decat you just tie it up out of the way Cheers I will have a look it's a tt vvti Link to comment Share on other sites More sharing options...
mrboomberang Posted May 23, 2016 Author Share Posted May 23, 2016 Think I've found where it goes luckily it's still on axle stands Link to comment Share on other sites More sharing options...
mrboomberang Posted May 23, 2016 Author Share Posted May 23, 2016 No that's not on my pipe Link to comment Share on other sites More sharing options...
Scooter Posted May 23, 2016 Share Posted May 23, 2016 So just to be clear the light came on when you first started it back up, presumably it runs fine looking at the idle on the picture of the clocks and warning light, so have you actually taken it for a drive and had the light stay on? Link to comment Share on other sites More sharing options...
ashloys Posted May 23, 2016 Share Posted May 23, 2016 Your handbrake? Link to comment Share on other sites More sharing options...
Scooter Posted May 23, 2016 Share Posted May 23, 2016 Your handbrake? That's what I've been getting at Link to comment Share on other sites More sharing options...
mrboomberang Posted May 23, 2016 Author Share Posted May 23, 2016 So just to be clear the light came on when you first started it back up, presumably it runs fine looking at the idle on the picture of the clocks and warning light, so have you actually taken it for a drive and had the light stay on? Not yet still on axle stands Link to comment Share on other sites More sharing options...
mrboomberang Posted May 23, 2016 Author Share Posted May 23, 2016 I have took the hand brake off just don't get it Link to comment Share on other sites More sharing options...
mrboomberang Posted May 23, 2016 Author Share Posted May 23, 2016 So just to be clear the light came on when you first started it back up, presumably it runs fine looking at the idle on the picture of the clocks and warning light, so have you actually taken it for a drive and had the light stay on? Yes Link to comment Share on other sites More sharing options...
ashloys Posted May 23, 2016 Share Posted May 23, 2016 That's what I've been getting at Skim read in work, apologies It could just be the handbrake position sensor that is faulty or something needs adjusted, happened on my old s13 and was a quick fix. Link to comment Share on other sites More sharing options...
mrboomberang Posted May 24, 2016 Author Share Posted May 24, 2016 I took off a blitz straight through double decat with no problem light I think it's cause it's on axle stands Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 24, 2016 Share Posted May 24, 2016 It's probably not level on the stands and the brake fluid level sensor is triggering the warning triangle. Top up the brake fluid up to just OVER the full line and see if it goes out. The light is nothing to do with the exhaust, it's coincidental, and probably the level the car is at as I have said. Link to comment Share on other sites More sharing options...
