kirky_123 Posted May 20, 2016 Share Posted May 20, 2016 (edited) hi all currently replacing my stock Toyota discs as my fronts are hardly worn but are warped and my rears are worn below minimum thickness after 6000 miles, doesn't sound like they lasted long to me, who knows, anyway bought some new front project mu SCR-GT fully floating discs and Stoptechs for the rear hoping these will withstand more abuse So anyway i thought i could incorporate my own brake ducts for the UK spec brakes to help keep the fronts cool, still in the process of making them all i need to do i weld the pipe onto the bracket, looking for advice and general thoughts to see if theres anything i could improve before i weld it, bracket was laser cut out of 2mm stainless and ive used the original caliper bolts as they look long enough and the pipe being welded onto the bracket will be as short as possible to clear everything on full lock. will be using 2 inch ducting, is this enough? got to be better then nothing. if these do turn out to be useful i could always make more Jonny Edited May 20, 2016 by kirky_123 (see edit history) Link to comment Share on other sites More sharing options...
Marcus GTE Posted May 20, 2016 Share Posted May 20, 2016 Love seeing stuff like this Link to comment Share on other sites More sharing options...
kirky_123 Posted May 21, 2016 Author Share Posted May 21, 2016 Thank you I'm hoping someone like mr Wilson could chime in with some insight Link to comment Share on other sites More sharing options...
