supra_jms Posted May 20, 2016 Share Posted May 20, 2016 Hi guys, Is the supra like every other car and when you double decat it you get the eml light come on? Does a lambda spacer work? Or is only way to cancel it a map? Quote Link to comment Share on other sites More sharing options...
Pete Posted May 20, 2016 Share Posted May 20, 2016 No. You keep the O2 sensor. Quote Link to comment Share on other sites More sharing options...
Wez Posted May 20, 2016 Share Posted May 20, 2016 No. You keep the O2 sensor. On an import you have the cat temp sensor which normally just gets strapped out the way, cant remember if this causes a light on the dash to pop up. Quote Link to comment Share on other sites More sharing options...
supra_jms Posted May 20, 2016 Author Share Posted May 20, 2016 Thanks guys Quote Link to comment Share on other sites More sharing options...
fastcar Posted May 20, 2016 Share Posted May 20, 2016 On an import you have the cat temp sensor which normally just gets strapped out the way, cant remember if this causes a light on the dash to pop up. No it shouldn't bring the light up for the cat temp sensor Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 20, 2016 Share Posted May 20, 2016 Sounds like you might need a fuel cut defender, do you also suffer fuel cut, or is it just the engine management light showing? Quote Link to comment Share on other sites More sharing options...
