eyefi Posted April 10, 2003 Share Posted April 10, 2003 which is return which is flow, top or bottom hose? thanks. Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted April 10, 2003 Share Posted April 10, 2003 Bottom is feed, and top one (half way along side) is return. Quote Link to comment Share on other sites More sharing options...
eyefi Posted April 10, 2003 Author Share Posted April 10, 2003 thanks Quote Link to comment Share on other sites More sharing options...
MONKEYmark Posted April 10, 2003 Share Posted April 10, 2003 eyefi the power steering tank has 2 pipes on, a small one on top and big one on bottom. the big one goes to the power steering pump near to the cam belt, its about 6-8" long pipe. the top smaller pipe goes down to your power steering cooler and there is an other pipe the other side of the power steering cooler that connects under car. is that what you mean or have i got it wrong. i did not think it would make a difference. as the fluid will travel through the power steering cooler pipe. the standard power steering cooler pipe is big and twisty, have replaced it with a smaller long u shaped cooler that came with the fmic. had me confused at the time. what you up to now, you always tinkering away Quote Link to comment Share on other sites More sharing options...
