Stock auto TT supra dyno j spec
Day881
Put my car on the dyno today at rk engineering in cornwall completely stock made 306bhp and 309 lbft dyno in 3rd
Very happy with those figures :) was running 0.74 bar
Engine Type - 2jz GTE non vvti
Engine Spec - Stock
Turbo - Stock J-spec
Fuel Used - shell v power
Exhaust - stock
Transmission - auto A340
ECU - stock
Dyno used - sun ram 12
Stock fuel pump
Stock induction
Power figure - 306
Torque figure - 309
Boost Pressure - 0.74 bar
Stock intercooler
Edited by Day881
Specs (see edit history)
This needs to be BPU mate, massive difference :)
Mine was dynoed at 370 with a double decat, Walbro 255 fuel pump with a restrictor ring at 1.1 BAR
I will be on a dyno hopefully in the next month or so, hoping for 400+
Yh that's the plan going bpu next :) all ready started buying some stuff for bpu not bad figures for stock TT though
  • 3 months later...
  • 2 months later...
Double decat 3" yes boost controller next then to 1.2 bar see what it makes then they don't always boost to 1 bar or more depends on size of restrictor ring mines from tb developments does boost to 1 bar on cold days
/QUOTE]
So its got a restrictor ring fitted then ?
Yes all jap specs have to else they over boost to like 1.6 bar once you have restrictor ring bring it to around 1 bar maybe less maybe more then you raise it to 1.2 using boost controller
/QUOTE]
Yes i know, i asked as you didn't mention you had a restrictor ring fitted, should be around 400 hp when you nudge
it up to 1.2 :)
