Stock Twin Turbos
Guest Gingerbreadman3
Usually they come with the manifold and all of the pipe work attached so it's a straight swap.
But you've only got the turbos themselves pictured
Thanks for that. Not sure what happened to the pipe work unfortunately as were changed before I got car.
  • 2 weeks later...
What Supra are they from? J-spec pre-facelift, J-spec facelift, UK spec?
Is there any shaft play?
What condition are the housing in? Any cracks?
What condition are the blades in?
Why were they changed?
J Spec supra - 1994 GZ Aero.
I have no idea what shaft play is but I can check if you tell me what to do or even video it.
No cracks at all on the housing.
Blades have no cracks on them
They came off the car in 2014 by previous owner ( not really sure why he gave me them ) He replaced them with bigger turbos.
Hope this helps. Let me know if there is anything else.
  • 4 weeks later...
  • 2 weeks later...
Guest NathanMcbeath94
Il pick these up on the 17th if you still have them, il be in Glasgow that weekend
