I've done the search. Access to rear bulbs?
dmad
Okay. Martin. I spent 10 minutes searching using every combination of the topic and got nothing.
So its either a stupid question, or......well probably a stupid question.
I'd like to change my rear fogs for the same 'always on' rear lights that are on when i switch my headlights on, so i may not have double brake lights (UK TT) but at least i have double normal ones. What I don't want to do is take off various bits of plastic to find that isn't where the access is...
So how do i get to the rear of the rear lights to change the bulbs? I went and bought spare tail lights (with the brake light filament in as well) to try this little task. It worked on the last car I had.
You have to remove the entire rear light, undo the two black headed bolts.
Did you search the manual that came with the car :D
Manual? I've configured anything from a VCR to a Windows 2000 active directory and haven't consulted a manual yet. Maybe if i had, i'd have done it all in half the time....
But who does? Cheers anyway - i thought that might be it. I'm just a lazy get.
