teddan Posted May 13, 2016 Share Posted May 13, 2016 During duno the engine started to doping coolant. This just happend during boost(1064hp). For each pull it pushed out 2liters of coolant at 3 bars of pressure. I am running titans head studs. From my point this happens due to head lift. Proberly need to re-torque the head studs or that the head was not machined properly. What do you guys think? Link to comment Share on other sites More sharing options...
teddan Posted May 13, 2016 Author Share Posted May 13, 2016 Link to comment Share on other sites More sharing options...
ATB Posted May 13, 2016 Share Posted May 13, 2016 Sounds and looks expensive either way Link to comment Share on other sites More sharing options...
teddan Posted May 14, 2016 Author Share Posted May 14, 2016 Sounds and looks expensive either way No worries mate. That also the oem diff was failing will cost me more.... Link to comment Share on other sites More sharing options...
and1c Posted May 14, 2016 Share Posted May 14, 2016 Could be head lift. Might be worth getting the head pressure tested too. Is there evidence of coolant around the bottom of the cylinder head after it has done this? Seems a bit weird if it would just pressurise internally only to that amount Link to comment Share on other sites More sharing options...
teddan Posted May 14, 2016 Author Share Posted May 14, 2016 (edited) Could be head lift. Might be worth getting the head pressure tested too. Is there evidence of coolant around the bottom of the cylinder head after it has done this? Seems a bit weird if it would just pressurise internally only to that amount You mean that it could be a crack in the head? No evidence that thete is coolant around the cylinder I am thinking of remove the head and measure it to se if it badly machined and crack testet it. I havent hear that a block would crack? Edited May 14, 2016 by teddan (see edit history) Link to comment Share on other sites More sharing options...
V8KILR Posted May 16, 2016 Share Posted May 16, 2016 Yes, blocks do crack. Check for cracks around water holes in the block once head removed. Link to comment Share on other sites More sharing options...
teddan Posted May 16, 2016 Author Share Posted May 16, 2016 There is always something to learn I have never before hard that a 2jz block has cracked. I will remove the head then and inspect that is going on there. If there where a crack in the block it will be shit! Too much money in that block and I suppose repair is not possible? Thanks V8kilr! Yes, blocks do crack. Check for cracks around water holes in the block once head removed. Link to comment Share on other sites More sharing options...
V8KILR Posted May 16, 2016 Share Posted May 16, 2016 The reason I know they do crack is that mine did so between the front head bolt hole and the closest water jacket hole. I swapped to another block, but the block was welded up and used in a lower power setup with no issues. Might have been okay for me, but I didn't want to take the chance. Yours may just be lifting the head, so it may be time for bigger and/or stronger head studs, unless Titan studs are already the best you can get? Link to comment Share on other sites More sharing options...
Tsia Posted May 16, 2016 Share Posted May 16, 2016 Ouch, glad to see you're taking it well, I'd have let out a few tears if I saw that! Link to comment Share on other sites More sharing options...
teddan Posted July 26, 2016 Author Share Posted July 26, 2016 Could a oem thermostat be able to create this pressurise? Due to higher rev for example Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 26, 2016 Share Posted July 26, 2016 Could a oem thermostat be able to create this pressurise? Due to higher rev for example No. Link to comment Share on other sites More sharing options...
teddan Posted August 27, 2016 Author Share Posted August 27, 2016 So I have removed the head but can't find any cracks either in the head nor the block. But it seems like the combustion has moved outside the expected area. See picture. I thinking about to machine the head again and go with the HKS head gasket instead of the multi layer ones. Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 27, 2016 Share Posted August 27, 2016 I would just accept that you are going way beyond the design limitations of the head and block and turn the boost down.... But if you are determined to see how much abuse you can give these things and aren't afraid of spending money then Wills rings and a custom fibre gasket to seal the oil and water ways might be worth investigating. Link to comment Share on other sites More sharing options...
teddan Posted August 27, 2016 Author Share Posted August 27, 2016 1000hp aren't so much these days and there are plenty of 1000hp supras in small sweden so it should definitely be able to handle the power somehow. I would just accept that you are going way beyond the design limitations of the head and block and turn the boost down.... But if you are determined to see how much abuse you can give these things and aren't afraid of spending money then Wills rings and a custom fibre gasket to seal the oil and water ways might be worth investigating. Link to comment Share on other sites More sharing options...
David P Posted August 27, 2016 Share Posted August 27, 2016 How does your compression & boost compare with other 1k Supra's? If you won't drop the boost, you may need to drop the compression? Link to comment Share on other sites More sharing options...
Dnk Posted August 27, 2016 Share Posted August 27, 2016 Before the head is machined make sure its flat by running a verdict clock along its width and length Link to comment Share on other sites More sharing options...
Mike2JZ Posted August 27, 2016 Share Posted August 27, 2016 Can you not get the head pressure or flow tested by a machine shop to tell if it's cracked? Link to comment Share on other sites More sharing options...
teddan Posted August 27, 2016 Author Share Posted August 27, 2016 How does your compression & boost compare with other 1k Supra's? If you won't drop the boost, you may need to drop the compression? Yes, Maybe I should use a 2,0mm head gasket instead. Compered to other 1k 2jz engines I don't see any difference in the spec's. Link to comment Share on other sites More sharing options...
teddan Posted August 27, 2016 Author Share Posted August 27, 2016 Can you not get the head pressure or flow tested by a machine shop to tell if it's cracked? Is it possible but due to the overpressure in the system was only shown during high boost is it not so likely that you could get at minimum 100bars pressure. (that is what at least have in the cylinders.) I am thinking of a Dye penetrant test otherwise. Link to comment Share on other sites More sharing options...
teddan Posted August 27, 2016 Author Share Posted August 27, 2016 Before the head is machined make sure its flat by running a verdict clock along its width and length Yes thanks! I think the machine shop that did the machining last time used to high speed so the surface was not perfect smooth so they some manual hand polishing.... Link to comment Share on other sites More sharing options...
Dnk Posted August 28, 2016 Share Posted August 28, 2016 Yes thanks! I think the machine shop that did the machining last time used to high speed so the surface was not perfect smooth so they some manual hand polishing.... Never heard of manually polishing a cylinder head face, fly cutting the face is as easy as it gets engineering wise, if they had too high a spindle speed i'm guessing they got vibration/chatter marks, pretty poor tbh !! All the best Link to comment Share on other sites More sharing options...
teddan Posted August 28, 2016 Author Share Posted August 28, 2016 Never heard of manually polishing a cylinder head face, fly cutting the face is as easy as it gets engineering wise, if they had too high a spindle speed i'm guessing they got vibration/chatter marks, pretty poor tbh !! All the best Exactly, and they try go removed the chatter marks with this stupid hand polishing. I was given this information that they did this after I had install the head on the engine:banghead: Thanks Link to comment Share on other sites More sharing options...
JamieP Posted August 28, 2016 Share Posted August 28, 2016 I had head lift problems a few times at high boost, L19's sorted it though, it had to be torqued down so hard it squashed the head a little in the end. I can't remember the torque settings now. Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 28, 2016 Share Posted August 28, 2016 (edited) Reinz make some of the best MLS gaskets in the industry, here's what they say on surface finish: http://www.victorreinz.com/EN/Service-Downloads/Practical-Information/Multi-layer-Steel-MLS-Cylinder-Head-Gaskets.aspx Edited August 28, 2016 by Chris Wilson (see edit history) Link to comment Share on other sites More sharing options...
