JDM RHD NA Supra converted to 2jz wiring issues. ( Pics inside)
Satansedan
Hey guys, I've had a Gem come my way and need a bit of wiring issues fixed.
Its a 94 RHD ( Originally NA) with an Aristo ( non vvti) 2JZ-GTE swap done using the JDM Aristo Harness and ECU. There is a short somewhere I have to find that keeps blowing the 10 amp fuse labeled "gauge" from the cabin fuse box diagram I found online. When the fuse blows the car wont start and its ignition related.
Other electrical problems are:
Headlights don't work with the switch
Foglights don't work with the switch
The Ignition ( gauge) short I mentioned earlier
The fuel pump is wired straight to the ignition
The speedometer works randomly when it wants to after hitting a bump
It had a slight "skip or miss" at idle sometimes and when it does this the car runs lean for a few seconds..
Here was the wiring done to the car when I received it:
Here is what I have done so far, using the diagrams I found online:
One problem I am noticing is if I start the cold and its cold, I give it gas it falls on its face and dies. If I flutter the throttle really fast it will eventually rev up and stay running but it sounds almost like a bad MAP or TPS when I flutter the gas to keep it running.... Any ideas?
