Air fuel ratio, too lean
FilS004
Hi all
I have rebuilt my engine (well put it back together) and I have found that although it seems to be running smoothly, the air fuel ratio is running around 21, and I think it should be around 12. As I have had the injectors cleaned and all of the cylinders are firing, what sensors could be causing this problem. I am guessing Lamda or something like that is telling the CU that there is not enough air in the mixture.
Any ideas?
Yeah, it is a wideband AFR, so I will reset the Lamda and see what happens. When I first ran up the engine, it was running around 12 and very smooth, and there is a definate difference in the engine running, so I guess that it has actually changed, just maybe by not that much.
I have only revved it up to 2K, so only just above idle, and there wasn't much of a problem, so it must be the Lambda need resetting
