Speedo cluster fuse
JoseSupra
Hi guys I have just changed my bulbs in me speed,Rev etc and now no lights, I've swapped bulbs round so see if if its the led but no. So next port of call is fuses now I take it it's the one under the driver side but can anyone tell me what one and what amp it is maybe a diagram as I'm really old and the back isn't what it use to be
Gracias
It should be a 10amp fuse and there will be a diagram on the inside of the fusebox lid which will show you which one you should be looking for. I had to change mine the other day. It should either say 'gauge' or 'panel'. One is for the lights and one is for the needles. I can't remember which.
Edited by CASHEYE (see edit history)
