Lee P Posted July 9, 2016 Share Posted July 9, 2016 It's running 1.8bar on pump fuel and 2.0bar on ethanol Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted July 10, 2016 Share Posted July 10, 2016 2 bar on ethanol! I'll be in touch Mr P, got to have me some of that! When rpm does it make full boost at? Quote Link to comment Share on other sites More sharing options...
Sheefa Posted February 1, 2017 Author Share Posted February 1, 2017 Wanted to keep this thread going with some more updates to keep track of all parts replaced and further modifications. Firstly, don't think I ever posted the dyno video whilst car wasn't being mapped by SRD at Abbey Motorsport so here it is.....stays on boost for an age Quote Link to comment Share on other sites More sharing options...
Sheefa Posted February 1, 2017 Author Share Posted February 1, 2017 (edited) So quick few changes completed over the last month or so. Replacemed by Boostlogic Crank Pulley for a new Fluidampr one. Nothing wrong with the old crank pulley and it was fully dampened which I actually wasn't aware of, but wanted to be on the safe side and got the Fluidampr at a great price. Thanks to Littlenum aka James for sorting this for me at his unit. We also stripped the PS pump, reservoir and lines as I was having a small PS leak somewhere near the bottom of reservoir. It turned out to be a weeping o-ring seal on the bottom of reservoir which is now all sorted It was doing my nut in! Thanks James. Also fitted my nice carbon engine bay Boxes thanks to Drift_Bear no MKiVGaz. They look great and only needed minor modifying needed to fit single setup even with aftermarket inlet. Have nearly completed refurbishing my UK rear brakes with new pads, seals, pistons and discs, just need to touch up the paint, refit and bleed system. I have then been going to town on the Suspension Components over the last few weeks to remove any traces of surface rust and protect everything against future corrosion with Hammerite black, Hammerite Waxoyl and ACF-50 spray. Having a garage is a god send and most of it is insulated so there's no moisture in the air. I have a couple of giant turbofan heaters in there too. Pics of work in progress, still a lot to do two corners remaining. Getting there, one corner sorted and protected. Happy with overall result. Edited February 1, 2017 by Sheefa (see edit history) Quote Link to comment Share on other sites More sharing options...
Sheefa Posted February 1, 2017 Author Share Posted February 1, 2017 (edited) As with all things car related, you start off one job and then run into another which wipes out all your time! Exhibit A. I began stripping all the arch lining trim, fuel tank guard, exhaust guard and other bits and noticed my Diff cooler wasn't in the best of conditions. Given I had a nice new OS Gilken Racing Diff fitted I wanted to ensure this was perfect so began refurbing and removing all rust, protecting etc. Before picture: After Pictures: Happy with the end result. Then it was on to the various covers, half way through taking this one carefully back to metal with a Dremel and Compressor Die Grinder removing all the surface rust and will protect fully with zinc paint and Hammerite once imperfections removed. I'm going to be overhauling everything I possibly can over the next 2 months and getting right under the chassis to remove any rust and under seal. Plenty to keep me busy. Fitted a Whifbitz Carbon Cooling Slam panel too which is a lovely piece of kit and finishes the bay of fresh nicely. More updates to follow. Edited February 1, 2017 by Sheefa (see edit history) Quote Link to comment Share on other sites More sharing options...
bignum Posted February 1, 2017 Share Posted February 1, 2017 Getting your hands dirty then Greg good lad. Quote Link to comment Share on other sites More sharing options...
Josh42 Posted February 1, 2017 Share Posted February 1, 2017 Good to see you getting stuck in Greg Nice to do a few of these jobs and tidy bits up! Quote Link to comment Share on other sites More sharing options...
Sheefa Posted February 1, 2017 Author Share Posted February 1, 2017 Thanks gents. It's a ballache but nice to know that doing it will be worth it in the long run and I'm certainly more confident now at giving things a bash Littlenum and Bignum are only a phone call away if it all goes wrong Quote Link to comment Share on other sites More sharing options...
Sheefa Posted February 1, 2017 Author Share Posted February 1, 2017 Any a couple of pictures from a meet just before Christmas Quote Link to comment Share on other sites More sharing options...
Luxluc Posted February 2, 2017 Share Posted February 2, 2017 Very nice mate. The bay looks great ... and the rest of the car too Quote Link to comment Share on other sites More sharing options...
Burna Posted February 2, 2017 Share Posted February 2, 2017 Very impressed mate, diff cooler looks great Reminds me I need to refresh mine. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted February 2, 2017 Share Posted February 2, 2017 Coming along great greg. Quote Link to comment Share on other sites More sharing options...
ShawnPreece Posted February 2, 2017 Share Posted February 2, 2017 need to bring this to one of the meets when the weather is better, need to see it looking great bud Quote Link to comment Share on other sites More sharing options...
Sheefa Posted February 2, 2017 Author Share Posted February 2, 2017 Thanks all, appreciate the kind words. Yes Shawn definitely up for a meet when the weather picks up Quote Link to comment Share on other sites More sharing options...
berg Posted February 2, 2017 Share Posted February 2, 2017 Nice work! Where does your cam cover breather go? Hidden catch tank somewhere? Quote Link to comment Share on other sites More sharing options...
Sheefa Posted February 2, 2017 Author Share Posted February 2, 2017 Nice work! Where does your cam cover breather go? Hidden catch tank somewhere? I used to have a nice shiny catch tank but removed it after recent upgrades. I think it uses an oil separator somewhere underneath but not entirely sure. I'll check later. Quote Link to comment Share on other sites More sharing options...
Style Posted February 3, 2017 Share Posted February 3, 2017 Well done for getting stuck in mate, I've not even had a chance to look at mine yet but these pics will certainly help when the time finally comes Quote Link to comment Share on other sites More sharing options...
Sheefa Posted February 3, 2017 Author Share Posted February 3, 2017 Well done for getting stuck in mate, I've not even had a chance to look at mine yet but these pics will certainly help when the time finally comes Thanks mate, just took my time and all worked out ok! Update - just bought full set of OEM rear suspension components - all control arms with new bolts and fixings etc. Eye watering cost but TCB did a great deal. Plan is to take my time treating and protecting them before fitting sometime next winter. Came in at just under £2k landed to U.K. from Japan. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted February 4, 2017 Share Posted February 4, 2017 nice work Gregg, I didn't realize some Supra came with diff coolers.. Quote Link to comment Share on other sites More sharing options...
Sheefa Posted February 4, 2017 Author Share Posted February 4, 2017 nice work Gregg, I didn't realize some Supra came with diff coolers.. Thanks mate. Just the UK specs I think. Not really needed unless you're doing hard track use but it's there and functioning so wanted to clean it up properly. Quote Link to comment Share on other sites More sharing options...
Burna Posted February 4, 2017 Share Posted February 4, 2017 Thanks mate. Just the UK specs I think. Not really needed unless you're doing hard track use but it's there and functioning so wanted to clean it up properly. /QUOTE] #UKSPECFTW To be honest it just another extra bit of weight we have to lug around lol Quote Link to comment Share on other sites More sharing options...
Sheefa Posted June 16, 2017 Author Share Posted June 16, 2017 Quick update: Found the cause of my clutch woes. A circlip had popped out en route home a year ago after clutch install which explained the issues getting it into gear on drive. Tried various things over the year and endless adjustment etc but all in all in vain. Lee at SRD has been great about everything and cannot thank him enough. Just gutted clutch was FUBARd especially as engagement was actually perfectly fine bizarrely. Going down OS Giken Twin route now getting it fitted by Littlenum as local to me shortly. Heavier pedal feel but I squat so should be fine ;-) * Fuel shield all refurbed and fitted. * Rear UK brakes fully refurbed and fitted. * Currently protecting all new rear suspension ready to fit in August time. * Received my nice new rear mounts made by a member on here. They look great and can use OEM bushes too. * Tim at TB Developments will be adapting my exhaust to remove 3" restriction too with titanium welding so I can run 3.5" straight through and push for more power in September! Oh and my little girl is in love with the car so doubtful I'll ever be allowed to sell anytime soon (great excuse to the Mrs anyway!) Got a few ideas in the pipeline too..... Quote Link to comment Share on other sites More sharing options...
np89 Posted June 16, 2017 Share Posted June 16, 2017 Was that on the assembly that holds the release bearing hub to the clutch face? Quote Link to comment Share on other sites More sharing options...
Sheefa Posted June 16, 2017 Author Share Posted June 16, 2017 Was that on the assembly that holds the release bearing hub to the clutch face? /QUOTE] Yes mate sure was. It "popped" out on way home so wasn't seated flush. Would explain everything. Quote Link to comment Share on other sites More sharing options...
np89 Posted June 16, 2017 Share Posted June 16, 2017 Yea definitely! Glad you are all sorted! Is the clutch totally not salvagable? Quote Link to comment Share on other sites More sharing options...
