Fuel filler cap help !!!
Why T
Right
So the fortune has custom filler necks behind the rear quarter window. The caps did not come with the shell unfortunately.
I have looked and looked and cannot find anything. These seam really really small.
External diameter is 48mm
Diameter between holes is 40mm
And internal diameter is 35mm
Please please someone help me find something. Really struggling now and there is way to much work to get them changed. :(
Regards
Shane
Fortune03 Aerotop manual single.
'Speed doesn't kill'
There is one in Demon tweeks. It`s listed as a weld in version but maybe those PCD holes were added by the builder of the car. Look at the dimensions of the Mocal small diameter flush fit cap. Outside diameter is 50mm and cap size is 38mm which is very close to what your dimensions are.
Yea I was looking at that but even the smaller one seams to big.
Is that the same as the one above?
Hahahaha yea that won't work as I don't have a flap haha
Which one are you on about as the one I think your on about is 44mm cap :/
