TRD-Rob Posted May 4, 2016 Share Posted May 4, 2016 I'm ordering some wheels for Japan and they need to be right first time as if there wrong thanks to me there's no sending them back,so I just need some help as I don't know what the best offset and wheel width is best. Im going with 18" so what would be the best width for the front and rear to get a nice flush look on a stock body car ? And also how do I get a bigger lip on the back then the front when ordering. Sorry if I'm hard to understand,if you need more info just ask. Thanks Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted May 4, 2016 Share Posted May 4, 2016 Hey mate.. I have SSR 19" bought in Japan, body is stock. The front is 9J offset 44. Rear is 10J offset 37. Fit is as per SSR recommendation for a stock body car. Pics in my garage.. Front lip is narrower than the rear.. Quote Link to comment Share on other sites More sharing options...
TRD-Rob Posted May 4, 2016 Author Share Posted May 4, 2016 Thanks for that mate but what makes the lip bigger on the back ? Only asking as I've seen loads of cars with a staggered fitting wheel but the lip front and back are the same. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted May 5, 2016 Share Posted May 5, 2016 Thanks for that mate but what makes the lip bigger on the back ? Only asking as I've seen loads of cars with a staggered fitting wheel but the lip front and back are the same. The rim is 3 piece, the lip is a separate piece from the face and the inner barrel. The width of the rim is 10J vs the front which is 9J so the inner barrel and lip end up wider. Quote Link to comment Share on other sites More sharing options...
ashloys Posted May 5, 2016 Share Posted May 5, 2016 Lip size on 3 piece wheels is dependant on offset. The higher the offset the smaller the lip, the lower the offset the bigger the lip etc. In 1 piece wheels most companies now design the wheels to simulate low offset style with bigger lips (i.e. Work Emotion D9R) regardless of the offset. So just depends on brand/design most of the time. But generally if you have a staggered set i.e. 9J front and 10J rear, it's likely the wider wheel will always have a slightly bigger dish too. Quote Link to comment Share on other sites More sharing options...
TRD-Rob Posted May 5, 2016 Author Share Posted May 5, 2016 Ok I understand it better now,I guess not seeing them in person before ordering the is just a bit worrying as there not cheap lol I've been told the best size to go for is. Front:18"9j et 45 Rear:18"10j et40 Now the et are not that far off but I was hoping for a one inch lip on the front and two inch or a tad over on the rears. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted May 5, 2016 Share Posted May 5, 2016 My rims sizes in more detail.. FR - 19 x 9.0J Offset 44mm, 34mm Lip.. RR - 19 x 10J Offset 37mm, 71mm lip See the link for the fitment pics as well.. As ashloys mentioned, depends on the manufacturer on how big the lip is. http://www.mkivsupra.net/vbb/showthread.php?250626-Ordered-my-wheels-Now-fitted-with-Pics! Quote Link to comment Share on other sites More sharing options...
ashloys Posted May 5, 2016 Share Posted May 5, 2016 Ok I understand it better now,I guess not seeing them in person before ordering the is just a bit worrying as there not cheap lol I've been told the best size to go for is. Front:18"9j et 45 Rear:18"10j et40 Now the et are not that far off but I was hoping for a one inch lip on the front and two inch or a tad over on the rears. What wheels do you actually want? Quote Link to comment Share on other sites More sharing options...
TRD-Rob Posted May 5, 2016 Author Share Posted May 5, 2016 Volk racing te37sl Quote Link to comment Share on other sites More sharing options...
Jellybean Posted May 5, 2016 Share Posted May 5, 2016 (edited) Zero offset is the wheel face in the centre of the wheel barrel , + 44 offset is the Wheel face moved 44mm from the center towards the outer lip (Roadside), in other words the 44mm of the wheel will sit behind the wheel face (Wheel Center line and Wheel face), when you start to get into negative offsets the outer lip (Roadside) is deeper and the inner rim (Hub side) is smaller (deep dish) Your offset can only go +/- from the center line before the wheel with start to foul the arch, then you get into Arch rolling to flare the arch to allow a greater negative offset to give the deep dish look Edited May 5, 2016 by Jellybean (see edit history) Quote Link to comment Share on other sites More sharing options...
ashloys Posted May 5, 2016 Share Posted May 5, 2016 (edited) Volk racing te37sl I just had a quick look at the size chart. I'd go for 18x10 ET40 and 18x9.5 ET40 or 45. They'd fit perfectly and maybe even need a very small spacer at the back to sit completely flush with a rolled arch and proper alignment. I've 9.5 ET 25 rear / 8J ET25 and it's pretty flush. The front could do with sitting out about another 5mm on the front to be more flush for my liking. EDIT: http://www.willtheyfit.com - use the calculator to work out differences in sizes and offsets Edited May 5, 2016 by ashloys (see edit history) Quote Link to comment Share on other sites More sharing options...
