Luc's SRD1000 Supra - Gen2 6870 turbo
Luxluc
Engine Type - Single Turbo was TT originally
Engine Spec - Built Engine with Mahle 86.5mm pistons and Carillo Rods, SRD Stage 5 Head with 280 camshafts, GReddy intake manifold, HKS exhaust manifold with screamer pipe.
Turbo - CEA Gen2 6870 1.00 A/R Twin Scroll.
Fuel Used - Luxembourg V-Power (only 3% ethanol) / E85
Fuel setup- ASNU 1500 injectors, triple Walbro 485 pumps, Flex fuel kit with teflon lines
Exhaust - 4" DP/MP with Whifbitz 4" Ti single box exhaust
Transmission - V160
ECU - Syvecs
Mapped By - SRD
Dyno Used - Abbey Hub Dyno
Power figure - 795 rhhp on VPower / 954 rhhp on E85
Torque figure - 655 ftlbs on VPower / 813 ftlbs on E85
Boost Pressure - 1.9 bar on VPower / 2.1 bar on E85
Due to the high torque figure in 4th gear (we overloaded the dyno), LeeP had to do the runs in 5th gear where the torque was a bit lower (750 ftlbs)
PUMP FUEL
E85
