kirky_123 Posted May 3, 2016 Share Posted May 3, 2016 Currently in the process of ordering new ccw wheels and the only problem I'm finding is are the r888 in 315/30/18 the only good option? Would a newer, slightly narrower tyre be a better option being the Michelin cup 2 tyre in 295/30/18? Either way can I still mount these onto a 11.5jj wheel, that way I can order them and decide when they turn up. Jonny Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 3, 2016 Share Posted May 3, 2016 I would just go R888 bud, be best for traction and they are not as bad in the wet as people say, they just struggle with standing water. Quote Link to comment Share on other sites More sharing options...
kirky_123 Posted May 3, 2016 Author Share Posted May 3, 2016 Ok then pal, I guess I'm only only ever out in the wet if I get caught out in the rain, I'll get ccw to send out the rears with R888 on (much cheaper then the uk) and I'll buy some pilot sport 4 for the front when they arrive. Quote Link to comment Share on other sites More sharing options...
hogmaw Posted May 3, 2016 Share Posted May 3, 2016 I have Michelin Pilot Sports 315/30/18 on my CCW rears and they are fine although I haven't tested them in the wet. Narrower tyre would suit fine too and might actually ride better. Quote Link to comment Share on other sites More sharing options...
jcbt Posted May 3, 2016 Share Posted May 3, 2016 We have Michelin pilot sport 2 in 315/30/18 on a works 11.5 j and they are great for grip wet and dry Quote Link to comment Share on other sites More sharing options...
Littler Posted May 3, 2016 Share Posted May 3, 2016 To increase grip have you considered a 305/35 R888, I believe you will need to get them imported from the US (CCW may well be able to help with that)? The increase in side wall would aid with grip/traction overall. Quote Link to comment Share on other sites More sharing options...
kirky_123 Posted May 4, 2016 Author Share Posted May 4, 2016 Didn't even know there was a 305/35/18, did just have a look though, would handling be sacrificed going with a taller tyre? 315/30/18 would be 646mm diameter 305/35/18 would be 670mm diameter Would there be any pros or cons between the two sizes? Quote Link to comment Share on other sites More sharing options...
