peter richards Posted May 2, 2016 Share Posted May 2, 2016 guys just been under the car changing the diff oil , and its looking pretty rusty under there , can it be cleaned up and protected or just leave it Link to comment Share on other sites More sharing options...
rider Posted May 2, 2016 Share Posted May 2, 2016 The last thing you should do is just leave it. Get it up on a ramp preferably or axel stand and give it a good go with a wire brush and rust convertor. Then zinc prime and paint. I wouldn't recommend underseal on top of what has been rust as that'll just hide its return making it worse next time around to tackle the rust. Link to comment Share on other sites More sharing options...
CHICO-SUPRA Posted May 2, 2016 Share Posted May 2, 2016 Hi bud, You should clean it with a wire brush degrease it and then a few coats of under seal. That should protect it and make it look clean under there. Gonna be doing mine hopefully next month. Link to comment Share on other sites More sharing options...
CHICO-SUPRA Posted May 2, 2016 Share Posted May 2, 2016 Like rider said bud rust convertor/protector on any bits of of rust then clean and paint. Aslong as the rust is removed or protected you should be able to under seal on top. Under seal should give it an extra layer of protection. Link to comment Share on other sites More sharing options...
peter richards Posted May 2, 2016 Author Share Posted May 2, 2016 ok thanks , on the to do list , see if i can find a lift be easier than in my garage Link to comment Share on other sites More sharing options...
