Mike2JZ Posted May 1, 2016 Share Posted May 1, 2016 Just put arp head studs on my engine, and the fastener size is 13mm. Thought the halfords 13mm bi-hex deep socket I had would be enough, but it dosen't clear the GE head as the wall is slightly too thick. Turned my workshop upside down trying to find something to fit, but no luck yet. Has anyone in the south east/london area got one I car borrow, or does anyone know where I can get one? Only one I've found online which looks like it will do is http://sg.rs-online.com/web/p/non-impact-sockets/0519759/ but it's dear. any suggestions? Quote Link to comment Share on other sites More sharing options...
robby a Posted May 1, 2016 Share Posted May 1, 2016 Just grind the outside of the socket till you can fit it through the hole Quote Link to comment Share on other sites More sharing options...
Andy Blyth Posted May 1, 2016 Share Posted May 1, 2016 An imperial 1/2 inch socket will fit better. It's a little less than 13mm. Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted May 1, 2016 Author Share Posted May 1, 2016 An imperial 1/2 inch socket will fit better. It's a little less than 13mm. Got a link to one I can buy? Can only find socket sets online Quote Link to comment Share on other sites More sharing options...
absz Posted May 1, 2016 Share Posted May 1, 2016 Here's a link of the one I bought but it still needed grinding down to fit https://www.cromwell.co.uk/shop/hand-tools/deep-skt-1-2inch-sd/kennedy-bi-hexagon-deep-sockets-1-2inch/f/4413 Quote Link to comment Share on other sites More sharing options...
Andy Blyth Posted May 1, 2016 Share Posted May 1, 2016 Got a link to one I can buy? Can only find socket sets online This one will work without any modification needed. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 1, 2016 Share Posted May 1, 2016 (edited) That Blyth man knows his ~#@& Quality sockets are usually thinner wall than crap ones as the decent material they use means they don't need as much of it Be wary of grinding sockets down, or turning them down. If they break up you may find bits of steel have disappeared down an oil drain hole, or down into a valve spring recess. Then you will be cussing. Edited May 1, 2016 by Chris Wilson (see edit history) Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted May 1, 2016 Author Share Posted May 1, 2016 thanks for the link blyth. i will get one asap Quote Link to comment Share on other sites More sharing options...
