car shakes
jza800
I have put some new wheels and used tires on my car, and the car shakes a little bit over 90 Km/t , and more when i goes faster, but shakes particularly violently when I brake to a stop, the wheels is new and tires are balanced , so that should not be the problem, it did it too with the others wheels, can it be that my brake disk are bad or???
there is no blur in the moving parts of the suspension so that should neather be the problem.. neather the ball joints or the tirerods..
Edited by jza800 (see edit history)
  • 4 weeks later...
I HAD THIS!!!! Turned out that the place that balanced the wheels had done it so wrong it was unreal, felt like I was on waves.....your wheels need rebalancing by sounds of it.
I have balancing the wheels my self 1 month ago all 4 on zero, i have had them on the balancer today, and the fronts are now showing that they need about 10g to 20g, and the rear are there only one wheel that need another 20 g to it... the wheels are about 5 years old baraly used.. What can be the reason for the sudden lack
