jza800 Posted April 30, 2016 Share Posted April 30, 2016 (edited) I have put some new wheels and used tires on my car, and the car shakes a little bit over 90 Km/t , and more when i goes faster, but shakes particularly violently when I brake to a stop, the wheels is new and tires are balanced , so that should not be the problem, it did it too with the others wheels, can it be that my brake disk are bad or??? there is no blur in the moving parts of the suspension so that should neather be the problem.. neather the ball joints or the tirerods.. Edited April 30, 2016 by jza800 (see edit history) Quote Link to comment Share on other sites More sharing options...
jcbt Posted April 30, 2016 Share Posted April 30, 2016 Worn disc's particularly when wear is on the inside of the disk will cause this problem and if you have spigot rings make sure they are the right ones. Quote Link to comment Share on other sites More sharing options...
jza800 Posted April 30, 2016 Author Share Posted April 30, 2016 i have checked the spigot rings, and they are the right size.. can worn disc also make the car shake in the sterring wheel, when you drive down the road and not use the brakes??? Quote Link to comment Share on other sites More sharing options...
shaky Posted April 30, 2016 Share Posted April 30, 2016 the answer to your question is NO, i can change from winter wheels to summer wheels with no problems, both sets have different offsets and tyre widths, have a read through this thread, ,,,, http://www.mkivsupra.net/vbb/showthread.php?333189-Steering-wheel-vibration-new-wheels Quote Link to comment Share on other sites More sharing options...
gdog1989 Posted April 30, 2016 Share Posted April 30, 2016 I HAD THIS!!!! Turned out that the place that balanced the wheels had done it so wrong it was unreal, felt like I was on waves.....your wheels need rebalancing by sounds of it. Quote Link to comment Share on other sites More sharing options...
jza800 Posted May 29, 2016 Author Share Posted May 29, 2016 I HAD THIS!!!! Turned out that the place that balanced the wheels had done it so wrong it was unreal, felt like I was on waves.....your wheels need rebalancing by sounds of it. I have balancing the wheels my self 1 month ago all 4 on zero, i have had them on the balancer today, and the fronts are now showing that they need about 10g to 20g, and the rear are there only one wheel that need another 20 g to it... the wheels are about 5 years old baraly used.. What can be the reason for the sudden lack Quote Link to comment Share on other sites More sharing options...
gdog1989 Posted May 31, 2016 Share Posted May 31, 2016 i have no idea why sorry... i just know that mine was a boat after a garage done mine....was done so wrong .... hope its sorted out your issue. Quote Link to comment Share on other sites More sharing options...
