Flan Posted April 27, 2016 Share Posted April 27, 2016 Installed led bulbs for all my rear lights and front indicators and they're now flashing too fast. Any way to correct this or other options? Cheers Quote Link to comment Share on other sites More sharing options...
L337 Posted April 27, 2016 Share Posted April 27, 2016 You need to wire in a resistor somehow, the flasher relay relies on a certain resistance from the normal bulbs to give a certain timing, with LED the resistance is far less making the relay flash quicker. Could measure the resistance of the Led bulb in comparison to the old ones and someone more knowledgeable could spec a resistor suitable. Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted April 27, 2016 Share Posted April 27, 2016 The easiest way is to swap out a FUSE relay that is located in the drivers footwell Wish I had the link for it but worked a treat on mine someone should be along with the link Quote Link to comment Share on other sites More sharing options...
Ric Posted April 28, 2016 Share Posted April 28, 2016 This is what i bought here: http://www.ebay.co.uk/itm/3-Pin-12V-Electronic-LED-Car-Flasher-Relay-Unit-Fix-Blinker-Indicator-Globe-/322011443232?hash=item4af960b020 Fixed it straight away and loads simpler than installing resistors everywhere. Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted April 28, 2016 Share Posted April 28, 2016 that was it Quote Link to comment Share on other sites More sharing options...
David P Posted April 28, 2016 Share Posted April 28, 2016 Easiest way is to leave the stock bulbs alone. Quote Link to comment Share on other sites More sharing options...
Flan Posted April 29, 2016 Author Share Posted April 29, 2016 Cheers Ric I think I'll buy that. Also going to attempt a homemade COB Led rings rear light setup sometime soon as it doesn't seem too difficult and looks great. There's a detailed guide at Supra Forums for anyone interested. Quote Link to comment Share on other sites More sharing options...
