Ian W Posted September 15, 2005 Share Posted September 15, 2005 searched to no avail.......really. my car already has Lenso GMs on it but they're 8.5 all round instead of having wider rears. question is, is this ruining the car or can i get away with just having wider tyres on the rear? also, if the wheels are crap then does anyone have a set of stock jobbies lying around i can pur-chase? (apologies to mods but didn't know to put it in technical or wanted section)... cheers guys... Link to comment Share on other sites More sharing options...
Ian W Posted September 15, 2005 Author Share Posted September 15, 2005 i know it's a bit of a noob question guys but it's basically whether you think that i'm worth just putting new rubber on the wheels are if i'm better off just ditching them and getting a 'new' set altogether? Link to comment Share on other sites More sharing options...
SupraSymz Posted September 15, 2005 Share Posted September 15, 2005 Mate, when I put my 19" Rials on my car, the style I wanted was available in all sorts of offset, but only 10" width, so that is what i have on all 4 corners. Whilst yours are 8" front and back, the point i'm making is that having the same wheel width doesn't seem to be much of a handling issue, the car feels fine...maybe if i were Jensen Button I'd notice some difference, but I'm not, so I don't. As for what the car looks like,...well beauty is in the eye and all that..., but ding dong, to my eye the car went up from "fine chickadee motor" to "babelicious happening machine", so go 18's or 19's, you know it makes sense. Symz Link to comment Share on other sites More sharing options...
Ian W Posted September 16, 2005 Author Share Posted September 16, 2005 cheers mate, basically just wanted to know if it was okay to run 8.5s all round....... they're 18s that are on there already! Link to comment Share on other sites More sharing options...
Suprachargedtt Posted September 16, 2005 Share Posted September 16, 2005 cheers mate, basically just wanted to know if it was okay to run 8.5s all round....... they're 18s that are on there already! It is if you have a n/a, from what ive read on here you need rear tyres 265 or wider on a TT Link to comment Share on other sites More sharing options...
Ian W Posted September 16, 2005 Author Share Posted September 16, 2005 aye, it's an N/A i've got with 8.5in rims all-round......just wanted to know the size of tyre i'm best having on the rear that's all. 255/40x18 or 265/35x18? Link to comment Share on other sites More sharing options...
nickyboy Posted September 16, 2005 Share Posted September 16, 2005 Run a search on "tramlining" and you will find most of the wheel/tyre size and width info. Don't think many people run the same with front and rear though. Link to comment Share on other sites More sharing options...
bignum Posted September 17, 2005 Share Posted September 17, 2005 hi,you should be ok with stock tyre widths ie 255 35,,rear 235 40 front.a 265 will be too wide on 8.5 inch rim. Link to comment Share on other sites More sharing options...
cornimac Posted September 18, 2005 Share Posted September 18, 2005 May I risk a slap and piggy-back this one? Reading this post brought fresh news - I hadn't thought about this being an issue. I have a J-spec '93 TT but am running 17 x 8" and 235/45 rubber (Yokohama Grand Prix) all round - from what people say here this seems to be a potential problem. Any advice? Apologies for that, Supra-man Link to comment Share on other sites More sharing options...
Ian W Posted September 19, 2005 Author Share Posted September 19, 2005 ....normally yes you would get a slap mate!! (just kidding) i'm quite glad i seem to be far from the only one suffering from this problem but it still seems no clearer as to what the solution is. some say that i'm fine to put 265/35s on the rear but i've also been told that they're too wide and i could only go as far as 255/40s (stock?) if ANYONE can clear this up once and for all please, please do so!! Link to comment Share on other sites More sharing options...
Guest nwrock69 Posted September 19, 2005 Share Posted September 19, 2005 talkin about wheels has anyone got a set of standard jap wheels? gettin desperate now cos the car is usless untill i can get it through the sva test,worst thing is i only need them for 1 day! would appreciate any help in finding some! also a standard air filter???????????? Link to comment Share on other sites More sharing options...
Nick Posted September 19, 2005 Share Posted September 19, 2005 I've got the following: Front (18*9) with 245/40ZR18 Rear (18*10) 275/35/ZR18 This gives a near perfect rolling radius to stock. The cars been slightly lowered (10mm rear, 35mm front I think) and there's no clearance problems at all. If you have the same size wheels all round then chances are they're the wrong offset too. Get some stock wheels on there, with stock tyre sizes and you're find the handling will be greatly improved... Link to comment Share on other sites More sharing options...
Jake Posted September 19, 2005 Share Posted September 19, 2005 some say that i'm fine to put 265/35s on the rear but i've also been told that they're too wide and i could only go as far as 255/40s (stock?) if ANYONE can clear this up once and for all please, please do so!! With an 18x8½" wheel you wouldn't want to go any more than 255/40/18 265/35/18 tyres can be safely fitted to wheels between 9" and 10½" wide. The Supra should have wider tyres at the rear. With those wheels of yours I would go with 235/45/18 on the pointy end and 255/40/18 on the back. Link to comment Share on other sites More sharing options...
Ian W Posted September 19, 2005 Author Share Posted September 19, 2005 thanks Jake think i'll be getting myself some 255/40x18 rubber for the rear in the mean-time until i can afford some new wheels...... thanks again. Link to comment Share on other sites More sharing options...
cornimac Posted September 20, 2005 Share Posted September 20, 2005 The Supra should have wider tyres at the rear. With those wheels of yours I would go with 235/45/18 on the pointy end and 255/40/18 on the back. Jake... as I already piggy backed this one, what would you recommend for my 17x8 rims? Running 235/45/17 all round at the mo. Cheers! Link to comment Share on other sites More sharing options...
Ian W Posted September 20, 2005 Author Share Posted September 20, 2005 i know it's probably worth nothing as i was asking the same question but what i've been told is basically that you should keep as close to stock as possible for best handling. ideally the rear wheels should be wider but if not then the rear tyres should be wider than the fronts. with your size of wheels you're probably better off running stock tyre sizes (although the stock 255/40 rears could be a little too large for your wheel (?))... how does your car handle with it's current set-up btw? Link to comment Share on other sites More sharing options...
