np89 Posted April 26, 2016 Share Posted April 26, 2016 Hi everyone, I was really looking for some advice on where people, through either technical knowledge or experience, would imagine my build figures will finish up. I'd like to have a fair idea of capability in order to plan ahead for mapping and setup for the road. The spec of the car is: Engine Spec - Built engine and head (all new guides etc) with BC 264 camshafts, BC Dual Valve Springs, Stock valves, HKS exhaust manifold with screamer pipe, CP Carillo 86.5mm Pistons (stock CR), Eagle Rods, ARP Head studs & ARP 2000 Rod Bolts, HKS 1.3mm Gasket (to compensate for block decking & head skim during build so should be stock CR), New Toyota OEM Oil Pump Turbo - BoostLabs S366 HF (Billet) 91-79 0.88 A/R Twin Scroll. Fuel Used - 97 RON (highest available for road fuel in NI) Fuel setup - ID1000cc, Walbro 485lph pump, AN-8 fuel lines Exhaust - 3" DP/MP with HKS Super Dragger exhaust Cooling- Whifbitz 3" intercooler Extras - AEM Aquamist Water meth injection (cooling only) Transmission - V160 & UK Spec Auto Diff ECU - Link G4+ Xtreme Power figure - ?? Torque figure - ?? Anticipated Boost Pressure - 1.8 bar Link to comment Share on other sites More sharing options...
Nodalmighty Posted April 26, 2016 Share Posted April 26, 2016 About 4 gallons to the mile. Link to comment Share on other sites More sharing options...
np89 Posted April 26, 2016 Author Share Posted April 26, 2016 About 4 gallons to the mile. Lol not quite the anticipated response Lyndon, although probably quite accurate just as well I have a daily derv! Link to comment Share on other sites More sharing options...
np89 Posted April 26, 2016 Author Share Posted April 26, 2016 No one any thoughts? Link to comment Share on other sites More sharing options...
Luxluc Posted May 4, 2016 Share Posted May 4, 2016 Check here http://www.mkivsupra.net/vbb/showthread.php?312236-Luc-s-SRD900-Supra-BL366-HF-turbo Link to comment Share on other sites More sharing options...
np89 Posted May 4, 2016 Author Share Posted May 4, 2016 Check here http://www.mkivsupra.net/vbb/showthread.php?312236-Luc-s-SRD900-Supra-BL366-HF-turbo Thanks Luc, that is promising indeed! Hopefully will do a similar figure! Link to comment Share on other sites More sharing options...
