Anticipated Figures from Spec
np89
Hi everyone, I was really looking for some advice on where people, through either technical knowledge or experience, would imagine my build figures will finish up. I'd like to have a fair idea of capability in order to plan ahead for mapping and setup for the road.
The spec of the car is:
Engine Spec - Built engine and head (all new guides etc) with BC 264 camshafts, BC Dual Valve Springs, Stock valves, HKS exhaust manifold with screamer pipe, CP Carillo 86.5mm Pistons (stock CR), Eagle Rods, ARP Head studs & ARP 2000 Rod Bolts, HKS 1.3mm Gasket (to compensate for block decking & head skim during build so should be stock CR), New Toyota OEM Oil Pump
Turbo - BoostLabs S366 HF (Billet) 91-79 0.88 A/R Twin Scroll.
Fuel Used - 97 RON (highest available for road fuel in NI)
Fuel setup - ID1000cc, Walbro 485lph pump, AN-8 fuel lines
Exhaust - 3" DP/MP with HKS Super Dragger exhaust
Cooling- Whifbitz 3" intercooler
Extras - AEM Aquamist Water meth injection (cooling only)
Transmission - V160 & UK Spec Auto Diff
ECU - Link G4+ Xtreme
Power figure - ??
Torque figure - ??
Anticipated Boost Pressure - 1.8 bar
