jza800 Posted April 24, 2016 Author Share Posted April 24, 2016 Your hopes have odd priorities? Drop the oil into a clean container and inspect it for metal fragments, if okay, you could then re-use it if you're tight. I have done that, no metal fragments of the ordinary, Quote Link to comment Share on other sites More sharing options...
jza800 Posted April 24, 2016 Author Share Posted April 24, 2016 Maybe check the belt tensioner pulley, it could be bouncing if the plunger is seized. Witch one, the timing belt or serptine belt ??? Quote Link to comment Share on other sites More sharing options...
Konrad Posted April 24, 2016 Share Posted April 24, 2016 Timing belt one. Also make sure that cam pulleys are torqued properly as they can cause these exact type of knocking. Quote Link to comment Share on other sites More sharing options...
Burna Posted April 24, 2016 Share Posted April 24, 2016 Timing belt one. Also make sure that cam pulleys are torqued properly as they can cause these exact type of knocking. That's the one, it will just bounce and knock if the plunger is seized in its block, as it's not apply any pressure to belt tensioning arm and wheel. Quote Link to comment Share on other sites More sharing options...
