Wanted Lsd differential options
girth45
TRD, Cusco, Kaaz, OS Giken et al are just new centre sections with the limited slip gubbins in them, that you fit to your existing crown wheel and pinion within your existing case. If you mean what complete assemblies are there with an LSD functionality, then only OE Toyota ones. I can't remember if you can no longer get a complete assembly or a crown wheel and pinion set from Toyota, something was no longer available about 18 months back.
Fitting (by me) is about £180 plus VAT and you will also need 2 new side bearings and side bearing seals. That's if you bring me a clean assembly out of the car.
Cost of the LSD centre section itself varies. The Giken is head and shoulders the best. Kaaz and Cusco will drive you crazy with grab, judder and noise. TRD is very civilised but not much preload for a serious car. You need to get the right LSD size to match your casing (big or small).
