12v mod with relay.
Guest Poopra1
To run a walbro 400 and above you need to do this mod, the pump will not run on the low voltage 9v off boost voltage the fuel pump ecu gives out , this mod is to give you a 12v feed constant but to still give you the safety features of the stock fuel ecu ie fuel cut in the event of a crash!!!!
If you dont fit the relay and wire directly to the 12v you will always have the fuel pump running as soon as you switch the ignition
Its your call pyro
I get the part that you need to get a wire directly from the battery to the relay so the pump gets the 12V all the time when the car is running but what I was after is if this 12V mod is necessary http://mkiv.com/techarticles/12v_mod/12v_mod.htm since the relay will trigger itself on voltage between 1,6V - 12V so from what I understand you dont need to do the 12V mod to the ECU and just take the cabel that feeds the pump from the ECU and run it by the relay that triggers the 12V from the battery, the original fuelpump cabel gives out 9-12V without the mod done but that shouldnt bother the relay that feeds the pump with 12V all the time since the relay will trigger itself on voltage between 1,6V - 12V.
  • 10 months later...
Good evening.
I have just installed a DW200 fuel pump on my 1998 Vvti Supra TT. (the car start fine with this new pump, not tested yet in "hard condition" , just one start and it work)
I have checked all "12V mod fuel pump" here and on supraforums.com.au, and i wanted to do the mod on my car, but i don't find the Fuel Pump ECU on my Vvti TT !!
can someone tell me where it's located ? (or if there is any fuel pump ECU on a Vvti TT ?)
in the trunk, where it's supposed to be, there is just the trunk light and a red electric stuff, but nothing to do with the pump (no big wire )
can someone help me? does this mod isn't needed on a Vvti TT ?
  • 3 months later...
I have the walbro 450LPH pump installed and working but I get that strange ticking from the relay now and then as for some others here. I run an new cabel from the battery to the relay and new cabels to the fuel pump. Is this the right way to connect the "trigger" cabel to the fuel ecu harness? It is spliced in to the RED/BLUE wire. Or should I do something else also to get rid of the strange on/off ticking of the relay?
Edited by EleCtRoN (see edit history)
[ATTACH=CONFIG]219675[/ATTACH]
You should get a correct drop out voltage relay
Ok
Check that you have the 9v supply from the fuel pump ecu to the coil of the relay and the 12v to the ecu through the contacts to the pump.
Its not uncommon for the fuel pump ecu to fail if thats what you have set up then youneed to monitor the voltages to the coil and see if your getting a drop in voltage. That being said if you have a bad connection this would also cause you problems. Also check that earth you have done not sure that insulation sound deadening conducts electricity ;)
Edited by mellonman (see edit history)
I have it set up like this now, any thoughts?
The chassi ground is under the same bolt that holds the fuel ecu but I will check it.
Should I run a wire between the factory fuel ecu 12V (blue wire) to the new wire that goes from the relay pin 30 to the new fuel pump?
  • 7 years later...
On 5/3/2016 at 12:22 PM, mellonman said:
No
The relay coil is energized by the 9v 12v feed and solid 12v runs through the contacts to the pump
You did look at the wiring diagram I done right its very simple http://www.mkivsupra.net/vbb/showthread.php?272714-12v-mod-will-this-work
What wire specifically, that comes out of the Fuel Pump ECU is the relay coil wire?
You use the 12v wire that supplies the FP Ecu- shown as blue in diagram - this is ignition switched live . Ie ignition on - relay operates and pump runs . The relay can now be a heavier duty relay and use heavier duty wire from battery to pump - fuse - 87-30-pump . The ECU is unplugged and does nothing . As stock the ECU puts out either 9v or 12v on the fuel pump line (brown) if you use this the new relay can drop out if at 9 volts (it’s a 12 v relay) - the inputs to the ECU were to show if the engine was running and stop fuel pump in an accident and to delay the fuel pump switching off with engine switched off - to prime the fuel lines for next start . And to drop the output to 9v at low power - this reduces the pump flow at idle to reduce the pump return to tank flow rate and reduce tank heating - at idle the majority of fuel is returning to tank and heated as its pressurised to a higher temp and picks up engine heat as it flows - effectively reducing the octane level when heated . These are the functions you lose when bypassing the ECU - you keep some of them if you use a 9v operating relay and wire as shown in diagram (lose the tank heating part ) The 9 volt switching is nothing to do with pump life as usually quoted and all about fuel heating - using a bigger flow pump adds to the return fuel temp - problem ? Not really unless you are sat for hours in traffic and then spank it at full power and high boost while losing some octane with temp
