RPS Streetmax Clutch with lighten CynRG flywheel
Dim Sum
Price £300.00 collected
Postage £20.00
This run and works perfectly. I have used this for a about 1000k miles or less. Most of the miles are done on the dyno or driving from and to the mappers. Had this for a year, I am only selling because I am upgrading the clutch because this won't hold the power I am going for.
This clutch is currently on the Supra its running 590ft/lbs and 710bhp. I am selling this clutch with the lighten flywheel but you can use the stock flywheel if you want. Bolts straight on.
This is a great clutch if you are planning to go single.
Information of the clutch and flywheel can be found here:
http://www.suprastore.com/rpsclutches1.html
I won't be removing this until around mid May, any questions please ask. I be asking for £50 deposit
Great clutch this, had it in my old car. The lightened flywheel really frees up the revs too, car feels much more responsive at low rpm. These are fully rebuildable too aren't they?
/QUOTE]
Thanks for the positive comments :) yeah does build the rpm quicker.
Not really sure about the rebuild part. But the way i drive my Supra, the clutch should be almost like brand new :D
