which oil sandwich plate?
Dim Sum
Faye Fischer who runs Speedflow's UK operation is a drag racer who has run at at a semi professional level and her knowledge of hoses and fittings is excellent. If anyone is unsure as to what they need she's more than qualified to advise. I have used her for hydraulics and pneumatics for years and years. She doesn't sell junk, so you can be sure they will be fine quality. Having said that I am NOT a fan of using sandwich plates with their added restriction unless vital. Can't you put the sensors elsewhere?
Chris what's your feelings on the oil filter relocation kits. As changing the oil filter on a TT is a nightmare without a lift.
/QUOTE]
I wouldn't use one, your just adding flow restriction and a load of potential leak interfaces. Just move the PAS reservoir if you want to change the filter from above.
I thought that would be your response. Any recommendations on locations to move the PAS reservoir? I was thinking of deleting the charcoal filter, could it go there?
Where would it be best to fit the sensors if I were not to get a oil sandwich plate?
Also I need to PM you maybe tomorrow, I brought a seal from you last year and I forgot what that seal was for lol. You was having a clear out :D
